Name of male plug searched
Hi all,
I am searching the male plug for the 4-pin white socket.
Does anyone knows the name?
JST XH Connector commonly found on lipo batteries
Model shops do extension charging leads for these which are male to female, cutting off one end gives you a pre terminated lead.
I would not suggest trying to terminate yourself.
The crimp dies for these cost 400 a pair.
Pololu do crimp pliers for 40 but they are for the larger pins found on dupont connectors.
Thank you very much!!!
The Crimp die ain't a problem. I work at a big company in the maintenance. There i got all stuff I need :stuck_out_tongue:
I knew I saw this connector somewhere, but couldn't remember ^^
Thanks a lot!
