Naming Arduino...
Hello everybody. A quick, probably stupid, question. Is it possible to give a unique name to an Arduino for serial identification purposes. I am trying to use several at once, and it can be frustrating trying to keep track of which one is plugged into which port.
To be clear, I am looking to make each Arduino easily identifiable in the Tools > Serial Port list.
Thanks!
It's not a stupid question, but I doubt you can do it.
which operating system and which arduino?
For FTDI based arduinos:
Mac OS uses the FTDI serial number as part of the device special file name, and FTDI has a windows tool that will allow you to change the serial number, which is 8 bytes.
Linux can use udev rules to assign particular device special file names based on the serial number.
Not sure on windows. You should be able to assign a com port number to a particular serial number, but I'm not sure.
For newer Arduinos with the Atmel chip as the USB interface, I think you're pretty much out of luck.
-j
kg4wsv: which operating system and which arduino?
Maybe one could tweak the Info.plist file in the OS X driver extension. You'd have to figure out what key to tweak.
I'm using an Uno, on a Mac. This is not FTDI, right?
I presume that the name is given by the computer, due to the fact that no matter which I plug in, there are only 2 possible names (for two possible USB ports). So, I guess the default "name" could be changed but that would only be port specific, not name specific.
Hmm...I guess it can't be done. Thats a shame.
The uno uses the Atmel for a USB interface, and it doesn't have a unique identifier. So yeah, sorry, you're out of luck.
The mac os USB-CDC driver assigns the device special file based on where you plug it in to the USB tree.
-j
