"nan" and "inf" returning to serial monitor from velocity calculation
Hello all, I am a new Arduino user. I am creating a portable weather station that calculates wind speed through a rotary encoder (Nidec RES20D50-201-1), tells the temperature, and tells the UV level. The problem I am having is when I try to calculate the positional data from the rotary encoder into velocity of the wind, it outputs nan until I start spinning the encoder, to which inf displays. This could be an error in the formula I used, but any help would be much appreciated. This is my code.
This is a demo for the Adafruit MCP9808 breakout
----> http://www.adafruit.com/products/1782
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
#include <Wire.h>
#include "Adafruit_MCP9808.h"
// Create the MCP9808 temperature sensor object
Adafruit_MCP9808 tempsensor = Adafruit_MCP9808();
#include <Wire.h>
#include "Adafruit_SI1145.h"
Adafruit_SI1145 uv = Adafruit_SI1145();
// include the library code:
#include <LiquidCrystal.h>
#include <Encoder.h>
Encoder myEnc(2, 3);
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 7, en = 8, d4 = 9, d5 = 10, d6 = 11, d7 = 12;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
unsigned long previousMillisEN = 0;
unsigned long previousMillisTemp = 0;
unsigned long previousMillisUV = 0;
#define temp 1000
#define UV 1000
#define ending 5000
#define R_C 0.031416
float AnSpeed;
float Speed;
  while (!Serial); //waits for serial terminal to be open, necessary in newer arduino boards.
  Serial.println("Adafruit MCP9808");
  // Make sure the sensor is found, you can also pass in a different i2c
  // address with tempsensor.begin(0x19) for example, also can be left in blank for default address use
  // Also there is a table with all addres possible for this sensor, you can connect multiple sensors
  // to the same i2c bus, just configure each sensor with a different address and define multiple objects for that
  //  A2 A1 A0 address
  //  0  0  0   0x18  this is the default address
  //  0  0  1   0x19
  //  0  1  0   0x1A
  //  0  1  1   0x1B
  //  1  0  0   0x1C
  //  1  0  1   0x1D
  //  1  1  0   0x1E
  //  1  1  1   0x1F
  if (!tempsensor.begin(0x18)) {
    Serial.println("Couldn't find MCP9808! Check your connections and verify the address is correct.");
    while (1);
  tempsensor.setResolution(0); // sets the resolution mode of reading, the modes are defined in the table bellow:
  // Mode Resolution SampleTime
  //  0    0.5°C       30 ms
  //  1    0.25°C      65 ms
  //  2    0.125°C     130 ms
  //  3    0.0625°C    250 ms
  Serial.println("Adafruit SI1145");
  if (! uv.begin(0x60)) {
    Serial.println("Didn't find Si1145");
    while (1);
  Serial.println("OK!");
long oldPosition = -999;
  unsigned long currentMillisEN = millis();
  tempsensor.wake();   // wake up, ready to read!
  // Read and print out the temperature, also shows the resolution mode used for reading.
  Serial.println (tempsensor.getResolution());
  float c = tempsensor.readTempC();
  Serial.print("Temp: ");
  Serial.print(c, 1); Serial.print("*C");
  tempsensor.shutdown_wake(1); // shutdown MSP9808 - power consumption ~0.1 mikro Ampere, stops temperature sampling
  // Uncomment if you have an IR LED attached to LED pin!
  //Serial.print("Prox: "); Serial.println(uv.readProx());
  float UVindex = uv.readUV();
  // the index is multiplied by 100 so to get the
  // integer index, divide by 100!
  UVindex /= 100.0;
  Serial.print("UV: ");  Serial.println(UVindex);
  long newPosition = myEnc.read();
  AnSpeed = (R_C*(newPosition - oldPosition))/((currentMillisEN - previousMillisEN)/1000);
  Speed = AnSpeed*(0.01);
  previousMillisEN = currentMillisEN;
  Serial.print(Speed);
  if (newPosition != oldPosition) {
    oldPosition = newPosition;
    // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("T: ");
  lcd.print(c, 1); lcd.print("*C");
  lcd.setCursor(0, 1);
  lcd.print("UV: ");
  lcd.print(UVindex);
  lcd.setCursor(9, 1);
  lcd.print("V: "); lcd.print(Speed);
You're likely getting division by zero. Print out your current and previous millis readings. If they're not at least a second apart, then that integer division by 1000 will produce zero. Try 1000.0 instead.
