nan output
Hi
I am trying to output the speed for my motor.
When my motor runs at a higher speed , I get the Speed output as 'inf' once and then continuous 'nan' after around 8000 rpm .
Could you tell me why the Serial is outputting 'nan ' instead of a proper value please.
Please find my code below :
//Arduino master device
#include <Wire.h>
#define TEN (float)10
int sectorFromHall(int hall1, int hall2, int hall3);
int rawHall1 =0 ;
int rawHall2=0;
int rawHall3 = 0;
int h1=3;
int h2=4;
int h3=5;
int previousSector = 6;
int hallSector = 6;
unsigned long time1 = 0;
unsigned long time2 = 0;
float MotorTime = 0;
float motorSpeed = 0.0;
int t=0;
int debugCounter = 0;
float speedFltrd = 0.0;
 Serial.begin(38400);
 pinMode(h1, INPUT);
 pinMode(h2, INPUT);
 pinMode(h3, INPUT);
 digitalWrite(h1, HIGH);
 digitalWrite(h2, HIGH);
 digitalWrite(h3, HIGH);
  Wire.begin(); // join i2c bus (address optional for master)
    rawHall1=digitalRead(h1);
  rawHall2=digitalRead(h2);
  rawHall3=digitalRead(h3);
  hallSector = sectorFromHall(rawHall1, rawHall2, rawHall3);
  previousSector = hallSector;
   Wire.beginTransmission(80); // transmit to slave device F2837   #0x50 (decimal is 80)
   Wire.write(hallSector);
   Wire.endTransmission();    // stop transmitting
  if(t==0){
          t=1;
          time1 = millis();
   if(previousSector != hallSector){
          time2 = millis();
          MotorTime = (((float)(time2 - time1))) * 0.001;  //time in sec
          motorSpeed = TEN / MotorTime; //convert to rpm
          speedFltrd += (motorSpeed - speedFltrd) * 0.01;   //0.01 is filter coefficient
              Serial.println(speedFltrd);
          t = 0;
	int sector;
	if ((hall1 == 0) && (hall2 == 1) && (hall3 == 1))
		sector = 0;
	else if ((hall1 == 0) && (hall2 == 1) && (hall3 == 0))
		sector = 1;
	else if ((hall1 == 1) && (hall2 == 1) && (hall3 == 0))
		sector = 2;
	else if ((hall1 == 1) && (hall2 == 0) && (hall3 == 0))
		sector = 3;
	else if ((hall1 == 1) && (hall2 == 0) && (hall3 == 1))
		sector = 4;
	else if ((hall1 == 0) && (hall2 == 0) && (hall3 == 1))
		sector = 5;
	{sector = 6;
	return sector;
Change millis() to micros() and adjust the corresponding constants - you were dividing
by zero.
