Nana error code
Hello, my Arduino nano recently stopped working here is the error code
Arduino: 1.8.5 (Windows 10), Board: "Arduino Nano, ATmega328P"
Sketch uses 8460 bytes (27%) of program storage space. Maximum is 30720 bytes.
Global variables use 519 bytes (25%) of dynamic memory, leaving 1529 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x75
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x75
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Any suggestions, I have used it many times in the past and have the right board and port checked
Thanks
Was the board manager upgraded from 1.6.20 (to e.g. 1.6.21)? If so, try the 'old bootloader' option in the processor menu for clones and original Nanos from before 2018.
If you're using an original Nano, produced in 2018, you will have to upgrade to board manager 1.6.21 (or newer but there seem to be some issues 1.6.22) and use the '328P' option in the processor menu.
