NAND Flash keeps returning FF after I write data
Hello, I am using Arduino UNO as a master and try to write and read data from 1GB NAND flash memory(MT29F1G01ABBFDSF // micron).
I am trying to write 0x00 to certain page(page #1, block #36). However, whenever I tried to read the data, the device kept returning 0xFF.
Plus, I was trying to disable block protection in void flash_reset() function,
Please kindly give your advice if I misunderstand anything.
// NAND FLASH SPI SETTING
// Master Device Setup
/* PAGE READ SEQUENCE
• 13h (PAGE READ command to cache) followed by 24-bit address
• 0Fh (GET FEATURES command to read the status) followed by 8-bit status register address
• 03h or 0Bh (READ FROM CACHE) followed by 4-bit dummy, 12-bit column address, 8-bit dummy
• 3Bh (READ FROM CACHE x2)
• 6Bh (READ FROM CACHE x4)
• BBh (READ FROM CACHE Dual I/O)
• EBh (READ FROM CACHE Quad I/O)
PAGE PROGRAM SEQUENCE
• 06h (WRITE ENABLE command)
• 02h (PROGRAM LOAD command)
• 10h (PROGRAM EXECUTE command)
#include <SPI.h>
#define CLOCK_SPEED           8000000
#define CS                    10                 // Chip select
#define COM_RESET             0xFF
#define COM_READ_ID           0x9F
#define COM_PAGE_READ         0x13              // Transfer data from the NAND Flash array to the cache register
#define COM_READ_FROM_CACHE   0x03              // Enable sequential reading from the cache buffer
#define COM_WRITE_ENABLE      0x06              // Enable PAGE PROGRAM OTP AREA PROGRAM, BLOCK ERASE
#define COM_WRITE_DISABLE     0x04              // Disable PAGE PROGRAM OTP AREA PROGRAM, BLOCK ERASE
#define COM_BLOCK_ERASE       0xD8
#define COM_PROGRAM_LOAD      0x02              // Erase(set all bits to 1) and write and move data bytes to the cache register (2176 bytes long)
#define COM_PROGRAM_EXECUTE   0x10              // Transfer data from cache register to the main array. Busy for T_PROG
#define COM_GET_FEATURES      0x0F
#define COM_SET_FEATURES      0x1F
#define READ_BLOCK_STATUS     0xA0
#define READ_CFG_STATUS       0xA0
#define READ_STATUS           0xC0
#define COM_UNLOCK_ALL        0x00
#define COM_LOCK_ALL          0xFF
#define DUMMY_BYTE            0x00              // 0000 0000  Dummy
#define ROW_ADD_1             0x08              // 0000 1000  Block 36
#define ROW_ADD_2             0x80              // 1000 0000  Page 1
#define COL_ADD_1             0x00              // Dummy bits + byte 0
#define COL_ADD_2             0x00              // Addressable up to 1000 0111 1111 (~ 2175 bytes)
#define TIME_POR              1000
#define TIME_CS                500               // Command deselect time
#define TIME_RD                500               // Read time
#define PAGE_NUM              2176
  SPI.begin();
  SPI.beginTransaction(SPISettings(CLOCK_SPEED, MSBFIRST, SPI_MODE0));
  SPCR |= _BV(MSTR);      // Master Setting
  digitalWrite(CS, HIGH);
  flash_reset();
  delay(TIME_POR);        // reset command requires settling time(t_por). GET_FEATURES command could be issued during this time.
  read_id();
  delay(TIME_POR);
  block_erase();
  delay(TIME_POR);
  page_program();
  delay(TIME_POR);
  page_read();
  delay(TIME_POR);
  while(true){
    // Do nothing.
void flash_reset(){
  byte block_status;
  byte cfg_status;
  byte sr_status;
  Serial.println("Resetting the device..");
  // 1. Reset device
  digitalWrite(CS, LOW);
  SPI.transfer(COM_RESET);
  // 2. Write Enable
  SPI.transfer(COM_WRITE_ENABLE);
  // 3. Unlock Block Protection
  SPI.transfer(COM_SET_FEATURES);
  SPI.transfer(READ_BLOCK_STATUS);
  SPI.transfer(COM_UNLOCK_ALL);
  // 4. Read Status register
  SPI.transfer(COM_GET_FEATURES);
  block_status = SPI.transfer(0xFF);
  SPI.transfer(READ_CFG_STATUS);
  cfg_status = SPI.transfer(0xFF);
  SPI.transfer(READ_STATUS);
  sr_status = SPI.transfer(0xFF);
  Serial.print("Block Status: ");
  Serial.println(block_status, BIN);
  Serial.print("CFG Status: ");
  Serial.println(cfg_status, BIN);
  Serial.print("SR Status: ");
  Serial.println(sr_status, BIN);
void read_id(){
  uint16_t manufacture_ID;
  uint16_t device_ID;
  byte read_status;
  SPI.transfer(COM_READ_ID);
  SPI.transfer(DUMMY_BYTE);
  manufacture_ID = SPI.transfer(0xFF);
  device_ID = SPI.transfer(0xFF);
  Serial.print("Manufacture ID: ");
  Serial.println(manufacture_ID, HEX);
  Serial.print("Device ID: ");
  Serial.println(device_ID, HEX);
void block_erase(){
  byte read_status;
  // 1. Write Enable
  // 2. Block Erase, 24-bit address (8bits dummy + 16bits RA)
  SPI.transfer(COM_BLOCK_ERASE);
  SPI.transfer(ROW_ADD_1);
  SPI.transfer(ROW_ADD_2);
  delay(TIME_CS);
  // 3. Get Features
  read_status = SPI.transfer(0xFF);
  Serial.print("Status after erasing: ");
  Serial.println(read_status, BIN);
void page_program(){
  byte my_data = 0x00;
  byte read_status;
  Serial.println("Programming pages...");
  // 1. Write Enable
  // 2. Program Load, 16-bit address (4bits dummy + 12bits CA)
  SPI.transfer(COM_PROGRAM_LOAD);
  SPI.transfer(COL_ADD_1);
  SPI.transfer(COL_ADD_2);
  for(int page = 0; page < PAGE_NUM; page++){
    SPI.transfer(my_data);
  // 3. Program Execute, 24-bit address (8bits dummy + 16bits RA)
  SPI.transfer(COM_PROGRAM_EXECUTE);
  delay(TIME_CS);
  // 4. Get Features
  Serial.print("Status after program: ");
void page_read(){
  byte my_rx;
  byte read_status;
  // 1. Page Read (13h), 24-bit addressing (8bits dummy + 16bits RA)
  SPI.transfer(COM_PAGE_READ);
  delay(TIME_RD);
  // 2. Get Features
  Serial.print("Status before reading: ");
  // 3. Read from Cache, 16-bit addressing (4bits wrap + 12bits CA) + following 8bits dummy
  SPI.transfer(COM_READ_FROM_CACHE);
  for(int pos = 0; pos < PAGE_NUM; pos++){
    my_rx = SPI.transfer(0xFF);
    if(pos%20 == 0){
      Serial.println("");
    Serial.print(my_rx, HEX);
    Serial.print(" ");
