Hello,
i am trying to create a Nand Flash Reader to create raw backups. I have connected a tsop48 socket with a flash to my arduino pro mini 3.3V 8MHz. The flash is from an old 32MB usb stick. First i am trying to read the manufacturer and the device id but i have no success yet.
Anybody with ideas or a similar project who can help me?
// Pin Setup
int datapin[8];
int we = 5;
int ale = 4;
int cle = 3;
int re = 14;
int ce = 15;
int rb = 16;
// Vars Setup
int inByte = 0;
unsigned char buffer[528];
for(int i=0;i++;i<=7)
datapin[i] = 6 + i;
pinMode(we, OUTPUT);
pinMode(ale, OUTPUT);
pinMode(cle, OUTPUT);
pinMode(re, OUTPUT);
pinMode(ce, OUTPUT);
// Serial Setup
Serial.println("NAND Flash Reader v1.0");
void ioop()
pinMode(datapin[i], OUTPUT);
digitalWrite(datapin[i], LOW);
void ioip()
pinMode(datapin[i], INPUT);
void ASSERT_WE() {digitalWrite(we, HIGH);}
void DEASSERT_WE() {digitalWrite(we, LOW);}
void ASSERT_ALE() {digitalWrite(ale, HIGH);}
void DEASSERT_ALE() {digitalWrite(ale, LOW);}
void ASSERT_CLE() {digitalWrite(cle, HIGH);}
void DEASSERT_CLE() {digitalWrite(cle, LOW);}
void ASSERT_RE() {digitalWrite(re, HIGH);}
void DEASSERT_RE() {digitalWrite(re, LOW);}
void ASSERT_CE() {digitalWrite(ce, HIGH);}
void DEASSERT_CE() {digitalWrite(ce, LOW);}
void SendCommand(byte cmdByte)
ASSERT_CLE();
WriteByte(cmdByte);
DEASSERT_CLE();
void SendAddress(byte addByte)
ASSERT_ALE();
WriteByte(addByte);
DEASSERT_ALE();
void WriteByte(byte outByte)
byte mask = 1;
int i = 7;
for (mask = 00000001; mask>0; mask <<= 1) {
if (outByte & mask) {
digitalWrite(datapin[i], HIGH);
else {
i--;
ASSERT_WE();
DEASSERT_WE();
void ReadByte(int length)
int bytecount = 0;
int pin = 7;
unsigned char tempByte;
while(bytecount < length) {
ASSERT_RE();
delay(10);
// Debug
for (int i = 0; i<8;i++) {
if (digitalRead(datapin[i]) == HIGH) {
Serial.print("1");
else {
Serial.print("0");
pin = 7;
buffer[bytecount] = tempByte;
bytecount++;
DEASSERT_RE();
if (Serial.available() > 0) {
char inByte = Serial.read();
Serial.println("send: ");
Serial.print(inByte, BYTE);
if (inByte == 'R') {
Serial.println("Reading...");
readDeviceID();
Serial.println("Done!");
void readDeviceID()
ioop();
delay(5);
ASSERT_CE();
SendCommand(0x90); // 90h = Read ID
SendAddress(0x00);
ioip();
//delay(50);
ReadByte(2); // 2 Bytes 1 = Manufacturer ID, 2= Device ID
DEASSERT_CE();
Serial.print("Manufacturer ID: ");
Serial.println(buffer[0], HEX);
Serial.print("Device ID: ");
Serial.println(buffer[1], HEX);
best regards
Xaptor
