Does anyone know why Nano 3 is not present when we download the library to Proteus? Nano 3 has the specificity to have Vin 5 and Vin 3.3, which is not featured if we go to proteus and select the nano to apply on the schematic. And I do need the 3.3 for my project.
Thank you for your time and reply Railroader, sorry I confused you. In fact you have on the Nano 3 the possibility to have 3.3v and 5v, this is because I am remaking a power station, where I will be using the Nano 3.2, the LMR33630, the ESP8266 and a DC DC bulk converter. If operated on 5v only, the result will overheat, so I try to have the right nomenclature Arduino on to Proteus to simulate, but Nano 3 is literally inexistante
Thank you, I am still working on schematic through Proteus, implying that I needed the exact same specifications, and cannot find the Nano 3. Still working on it> , as StefanL38 forwarded another fact about the Nano 3.
Many thanks StefanL38, as we say, devil is in the detail, and I think that you and Railroader just put me in the right direction. In fact, I have go to the drawing board.
Another "silly" question: The "+3V3" i believe would have been to connect with BME280, how does it impact on Proteus if it is not apparent, despite being physically present on the Nano 3?
I don't understand what you want to say with this.
I have no experience with protheus. I'm sure there is a specialised protheus-user-forum
if it is really important to use the protheus-simulator.
Not knowing protheus and how realstic protheus really is. I guess if you change from protheus-simulation to real world
all the things protheus can not simulate will bite you
too long wires or too much EMV-noise on the I2C-bus.
Forgotten pullup-resistors
destroyed sensors through electrostatic discharge
wiggle-waggle-contact on loose wires
So if your plan was
developping the whole system on protheus for weeks and then the last 5 days
build it in real hardware
change the numbers
do some initial steps for 5 days using protheus until your real arduino nano, three pieces of each sensor, a digital multimeter arrived
and then do most of the work on the real hardware. If the real arduino stays at school
I would even recommend to duplicate the whole system for beeing able to work at home on real hardware too.
third best option using a simulator at home
