I managed to build out the entire circuit with all the buttons and Thumbstick working perfectly. The problem now is that I am not able to figure out how to send Esc, Shift, and Ctrl from the arduino so that it registers correctly on PC.
I have tried all the different Hex and decimal codes that I could find for these keys, but I have not bee able to get them to work.
Does anyone else know what I could be doing wrong?
I used the USBHID -> Keyboard example that was included under the Nano 33 BLE, and build everything up from there.
I am using these two libraries that were included in the example, and they have gotten me this far:
#include "PluggableUSBHID.h"
#include "USBMouseKeyboard.h"
But I don't see any KeyPress type methods being named in either of these.
Could anyone please help point me in the right direction?
EDIT: Including my code for reference. (I'm very much still a beginner at this)
Summary
// This Arduino Script is to attempt to emulate a "Gaming Keyboard" as a one handed controller
// - Short term goals:
// - 1) Get at least 9 push buttons plus the Thumbstick button mapped to individual keys.
// - This had been done for the most part, keys still left to map once I have figured out how:
// - Shift
// - Ctrl
// - Esc
// - 2) One of the 9 buttons should act as a "modifier" to allow two mappings per button. - Done
// - 3) Use the Thumbstick as WASD movement. - Done
// - Long term goals:
// - 1) Be able to switch the controller over to emulate half an actual controller with a flip switch.
// - 2) Replace the trigger push button with a force sensor to allow it to act as a "throttle"
// similarly to how most controller triggers work.
// - Optional goals:
// - 1) Add a battery and charger module so that we can go wireless via Bluetooth.
// - 2) Add option to enable the motion sensors and use that for extra controller options,
// e.g. VR controller(?)
USBMouseKeyboard Keyboard;
// This is where the variables are set to map the PIN positions for the Thumbstick axis, and each individual button.
const int jxPin = A0;
const int jyPin = A1;
const int jsPin = 12;
const int b1Pin = 2;
const int b2Pin = 3;
const int b3Pin = 4;
const int b4Pin = 5;
const int bpPin = 6;
const int tgPin = 7;
const int stPin = 8;
const int slPin = 9;
const int fnPin = 11;
// This is where additional variables are set to read the current value for each PIN.
int jxVal;
int jyVal;
int jsVal;
int b1Val;
int b2Val;
int b3Val;
int b4Val;
int bpVal;
int tgVal;
int stVal;
int slVal;
int fnVal;
// These values are just here to easily configure the "dead zone" for the Thumbstick.
int up = 462;
int down = 562;
int left = 562;
int right = 462;
//Any delays go here for easy access.
int dts = 800;
int dtb = 0 ;
//Setting the pinMode for each of the pins.
pinMode(jxPin, INPUT);
pinMode(jyPin, INPUT);
pinMode(jsPin, INPUT_PULLUP);
pinMode(b1Pin, INPUT_PULLUP);
pinMode(b2Pin, INPUT_PULLUP);
pinMode(b3Pin, INPUT_PULLUP);
pinMode(b4Pin, INPUT_PULLUP);
pinMode(bpPin, INPUT_PULLUP);
pinMode(tgPin, INPUT_PULLUP);
pinMode(stPin, INPUT_PULLUP);
pinMode(slPin, INPUT_PULLUP);
pinMode(fnPin, INPUT_PULLUP);
// Prepping the buttons with a default state.
digitalWrite(jsPin, HIGH);
digitalWrite(b1Pin, HIGH);
digitalWrite(b2Pin, HIGH);
digitalWrite(b3Pin, HIGH);
digitalWrite(b4Pin, HIGH);
digitalWrite(bpPin, HIGH);
digitalWrite(tgPin, HIGH);
digitalWrite(stPin, HIGH);
digitalWrite(slPin, HIGH);
digitalWrite(fnPin, HIGH);
delay(dts);
// This is where the values for each PIN is read.
jxVal = analogRead(jxPin);
jyVal = analogRead(jyPin);
jsVal = digitalRead(jsPin);
b1Val = digitalRead(b1Pin);
b2Val = digitalRead(b2Pin);
b3Val = digitalRead(b3Pin);
b4Val = digitalRead(b4Pin);
bpVal = digitalRead(bpPin);
tgVal = digitalRead(tgPin);
stVal = digitalRead(stPin);
slVal = digitalRead(slPin);
fnVal = digitalRead(fnPin);
//This is where I attempt to map the Thumbstick directions to WASD, and this seems to work perfectly (I hope)
if (jxVal < up){
Serial.print("Pressing W - Joystick X value: ");
Serial.println(jxVal);
Keyboard.key_code(0x77,0);
if (jxVal > down){
Serial.print("Pressing S - Joystick X value: ");
Keyboard.key_code(0x73,0);
if (jyVal > left){
Serial.print("Pressing A - Joystick Y value: ");
Serial.println(jyVal);
Keyboard.key_code(0x61,0);
if (jyVal < right){
Serial.print("Pressing D - Joystick Y value: ");
Keyboard.key_code(0x64,0);
if (jsVal == LOW){
if (fnVal == LOW){
Serial.println("Pressing T");
Keyboard.key_code(0x74,0);
Serial.println("Pressing Space");
Keyboard.key_code(0x20,0);
delay(dtb);
// This is where the four "Primary Buttons" are being mapped to Keys.
if (b1Val == LOW){
if (fnVal == LOW){
Serial.println("Pressing Z");
Keyboard.key_code(0x7a,0);
Serial.println("Pressing Q");
Keyboard.key_code(0x71,0);
delay(dtb);
if (b2Val == LOW){
if (fnVal == LOW){
Serial.println("Pressing X");
Keyboard.key_code(0x78,0);
Serial.println("Pressing E");
Keyboard.key_code(0x65,0);
delay(dtb);
if (b3Val == LOW){
if (fnVal == LOW){
Serial.println("Pressing C");
Keyboard.key_code(0x63,0);
Serial.println("Pressing R");
Keyboard.key_code(0x72,0);
delay(dtb);
if (b4Val == LOW){
if (fnVal == LOW){
Serial.println("Pressing V");
Keyboard.key_code(0x76,0);
Serial.println("Pressing F");
Keyboard.key_code(0x66,0);
delay(dtb);
// This is where the Bumper and Trigger are mapped to Keys
if (bpVal == LOW){
if (fnVal == LOW){
Serial.println("Pressing B");
Keyboard.key_code(0x62,0);
Serial.println("Pressing CTRL");
Keyboard.key_code(0x11);
delay(dtb);
if (tgVal == LOW){
if (fnVal == LOW){
Serial.println("Pressing G");
Serial.println("Pressing Shift");
Keyboard.key_code(0x10);
delay(dtb);
// This is where the Start and Select buttons are mapped to Keys
if (stVal == LOW){
if (fnVal == LOW){
Serial.println("Pressing I");
Keyboard.key_code(0x69,0);
Serial.println("Pressing Esc");
Keyboard.key_code(0Xb1);
delay(dtb);
if (slVal == LOW){
if (fnVal == LOW){
Serial.println("Pressing M");
Keyboard.key_code(0x6d,0);
Serial.println("Pressing Tab");
Keyboard.key_code(0x09,0);
delay(dtb);
