Nano 33 BLE is not connecting (I think)
Hello!
I am very new to this tech stuff. I am currently struggling with connecting my microcontroller to Edge Impulse. I connected the microcontroller to my PC via USB and I do not think my PC recognizes it (LEDs are blinking etc.)
Does anyone have a solution to this?
Thanks in advance!
Welcome to the forum
Is a new COM port created when you plug in the Nano ?
Hello, thanks for the quick response.
I do not think a new COM port is created (it should show on the device manager, right?). when I plug the USB cable out and back in no new device is being recognized by the device manager. this is a bit frustrating since I bought the microcontroller about a week ago.
Re you sure that the USB lead that you are using has data lines in it and is not just a charging lead ?
I did not even know there were different types of USBs. I will order the right ones!
this is the one I use:
You cannot tell which type it is by looking. Was that lead supplied with a device or did you buy it separately ?
I found it at home. I am not sure.
is there a way for me to check?
Try to transfer data. If you can't, it is a charging cable.
Have you got a mobile 'phone that uses the same USB connector as the Nano ?
No. I only have a music box that uses the charger.
What is the best way of doing that? :slight_smile:
That's why I was asking if you had a 'phone, so that you could try a data transfer
Do you know anyone with a compatible 'phone ?
