So here my code. Probably the creation of the file can be simplied. All the functions and structures are defined in the UserTypes.h
/*VERSION 1.0 IMU VL53L0X LOG WITH ARDUINO NANO BLE 33*/
// INCLUDE LIBRARIES
#include <SPI.h>
#include <SdFat.h>
#include "UserTypes.h"
// SET BAUDRATE OF GPS. Need to be configured in u-center program
#define GPS_BAUDRATE 9600 //GPS configured in u-center
// Log file base name. Must be six characters or less.
#define FILE_BASE_NAME "Data"
// Declare sdfat name
SdFat SD;
// SD chip select pin. Be sure to disable any other SPI devices such as Enet.
const int chipSelect = SS; //required for SD reader
// PIN TO PPS OF GPS FOR INTERRUPT
const int tpsInt = 2; //timepulse interrupt
const uint32_t FILE_BLOCK_COUNT = 128;
const uint8_t BASE_NAME_SIZE = sizeof(FILE_BASE_NAME) - 1;
char fileName[13] = FILE_BASE_NAME "00.txt";
// Log file.
SdFile logfile;
#define error(msg)
// Variables
uint32_t logTime;
uint32_t lastADCsample;
static const uint32_t ADC_INTERVAL = 10; //ms between sensor recordings
static const uint8_t MAX_ADC_SAMPLES = 100 / ADC_INTERVAL; // evenly-spaced between gps recordings
uint8_t ADCsamples = 0;
// Boolean definition
bool tasto = 1; // Boolean to start and stop the log
bool prev_tasto;
unsigned int millisAtEpoch = 0; // time at interrupt
volatile boolean epochFlag; // Flag for interrupt
volatile boolean noGpsFlag; // Flag to stop gps during sensor recording
static const int LED = 13; //SD light control
// STRUCTURE FOR NAV_PVT GPS FORMAT DEFINITION
NAV_PVT pvt;
// User functions. Edit writeHeader() and logData() for your requirements.
// Write data header.
void writeHeader() {
logfile.print(F("micros"));
logfile.print(F(",xSuspF,latitude,longitude,altitude,gSpeed,sAcc"));
logfile.println();
// Create a new preallocated txt file and then record on it
void logData() {
createTxtFile();
writeHeader();
recordFile();
while (!Serial) {
SysCall::yield(); // DO NOTHING UNTIL SWITCH IS TURNED ON
if (!SD.begin(chipSelect, SD_SCK_MHZ(50))) {
SD.initErrorHalt(); // INIT SD CARD
// BLINK LED 13 UNTIL SETUP IS FINISHED
if (!SD.begin(chipSelect)) {
while (true) {
digitalWrite(LED, HIGH);
delay(75);
digitalWrite(LED, LOW);
delay(75);
// DEFINE PIN FOR INPUT AND OUTPUT
pinMode(7, INPUT);
pinMode(6, OUTPUT);
userSetup() ;
// DEFINE PIN COMING FROM GPS PPS
attachInterrupt(digitalPinToInterrupt(tpsInt), isr, RISING); //Interrupt for GPS time pulse
/*// DEBUG ONLY
while (Serial1.available())
char c = Serial1.read();
Serial.write(c); // uncomment this line if you want to see the GPS data flowing
// READ INPUT BUTTON BEFORE TO START LOGGING
tasto = digitalRead(7);
if (!prev_tasto && tasto) {
prev_tasto = tasto;
digitalWrite(6, HIGH); //On shows GPS is recording
// START LOGGING ROUTINE
logData();
// CREATE PREALLOCATED 8KB FILE ON THE SD CARD
void createTxtFile() {
// max number of blocks to erase per erase call
const uint32_t ERASE_SIZE = 262144L;
uint32_t bgnBlock, endBlock;
// Find an unused file name.
if (BASE_NAME_SIZE > 6) {
error("FILE_BASE_NAME too long");
while (SD.exists(fileName)) {
if (fileName[BASE_NAME_SIZE + 1] != '9') {
fileName[BASE_NAME_SIZE + 1]++;
} else if (fileName[BASE_NAME_SIZE] != '9') {
fileName[BASE_NAME_SIZE + 1] = '0';
fileName[BASE_NAME_SIZE]++;
error("Can't create file name");
// Create new file.
Serial.println(F("\nCreating new file"));
logfile.close();
if (!logfile.createContiguous(fileName, 512 * FILE_BLOCK_COUNT)) {
error("createContiguous failed");
// Get the address of the file on the SD.
if (!logfile.contiguousRange(&bgnBlock, &endBlock)) {
error("contiguousRange failed");
// Flash erase all data in the file.
Serial.println(F("Erasing all data"));
uint32_t bgnErase = bgnBlock;
uint32_t endErase;
while (bgnErase < endBlock) {
endErase = bgnErase + ERASE_SIZE;
if (endErase > endBlock) {
endErase = endBlock;
if (!SD.card()->erase(bgnErase, endErase)) {
error("erase failed");
bgnErase = endErase + 1;
// RECORD FILE ROUTINE (MISSING TRUNCATING AT THE END OF THE FILE
void recordFile() {
bool closeFile = false;
Serial.println(F("Logging..."));
uint32_t logTime = 0 ;
// Check if file is closed
while (1) {
logTime += ADC_INTERVAL;
if (prev_tasto && !tasto) {
prev_tasto = tasto;
closeFile = true;
logfile.close();
digitalWrite(6, LOW);
Serial.println(F("File closed"));
if (closeFile) {
break; // RESET BOARD READY FOR NEW LOG
if (epochFlag == true) { //checks if timepulse interrupt has occured
millisAtEpoch = millis(); //sets approxime time of timepulse
epochFlag = false; //resets for next timepulse
if ( processGPS() ) {
logFile.print(logTime); //point at which message parsing has finished
logFile.print(",");
logFile.print(pvt.lat); //latitude
logFile.print(",");
logFile.print(pvt.lon); //longitude
logFile.print(",");
logFile.print(pvt.hMSL); //altitude at sea level
logFile.print(",");
logFile.print(pvt.velN); //velocity north
logFile.print(",");
logFile.print(pvt.velE); //velocity east
logFile.print(",");
logFile.print(pvt.velD); //velocity down
logFile.print(",");
logFile.print(pvt.numSV); //number of satellites
logFile.print(",");
logFile.print(pvt.gSpeed); //ground Speed mm/s
logFile.print(",");
logFile.print(pvt.sAcc); //speed accuracy estimate
logFile.println();
ADCsamples = 0; //reset the ADC samples couter to 0
lastADCsample = millis() - ADC_INTERVAL; // force the 1st ADC sample
if ( (millis() - millisAtEpoch) > 200 and (noGpsFlag == false)) { //asumes no gps fix when no epoch recieved within 200ms.
noGpsFlag = true;
if ((ADCsamples < MAX_ADC_SAMPLES) and
((millis() - lastADCsample) >= ADC_INTERVAL) or ((noGpsFlag == true) //when GPS outage, operates indefinitly at set sample rate
and ((millis() - lastADCsample) >= ADC_INTERVAL)) )
uint8_t inputValues [10];
for(int i=0; i<10; i++){
inputValues[i] = analogRead(A5);
// logFile.print(logTime);
// logFile.print(','); // <-- needed?
logFile.println(inputValues[i]);
ADCsamples++;
lastADCsample += ADC_INTERVAL;
// FLAG SWICTH WHEN INTERRUPS COMES FROM PPS OF GPS
void isr() {
epochFlag = true; //timepulse has indicated epoch
noGpsFlag = false; //false as GPS is recieving messages
bool processGPS() { //loop comes here to check if a valid message is available.
static int fpos = 0;
static unsigned char checksum[2];
const int payloadSize = sizeof(NAV_PVT);
while ( Serial1.available() ) {
byte c = Serial1.read();
if ( fpos < 2 ) {
if ( c == UBX_HEADER[fpos] )
fpos++;
fpos = 0;
else {
if ( (fpos - 2) < payloadSize )
((unsigned char*)(&pvt))[fpos - 2] = c;
fpos++;
if ( fpos == (payloadSize + 2) ) {
calcChecksum(checksum);
else if ( fpos == (payloadSize + 3) ) {
if ( c != checksum[0] )
fpos = 0;
else if ( fpos == (payloadSize + 4) ) {
fpos = 0;
if ( c == checksum[1] ) {
return true;
else if ( fpos > (payloadSize + 4) ) {
fpos = 0;
return false;
void calcChecksum(unsigned char* CK) { //Checks if message has been parsed correctly
memset(CK, 0, 2);
for (int i = 0; i < (int)sizeof(NAV_PVT); i++) {
CK[0] += ((unsigned char*)(&pvt))[i];
CK[1] += CK[0];
The loop to log the analog signal written like this is simply not working, but i do not know how to write it in a good way.
