Nano 33 BLE Sense Machine Learning Problem
I have successfully run gesture example using machine learning. But I when I want to run the machine learning for my project, I got some problems. My model has 10 inputs and 10 outputs. When I add code to run inferencing, the board goes into the error mode with yellow light flushing. The code that causes the error is
TfLiteStatus invokeStatus = tflInterpreter->Invoke();
Here is my entire code which also has I2C communication. Thanks.
// Wire Slave Sender
// by Nicholas Zambetti <http://www.zambetti.com>
// Demonstrates use of the Wire library
// Sends data as an I2C/TWI slave device
// Refer to the "Wire Master Reader" example for use with this
// Created 29 March 2006
// This example code is in the public domain.
#include <Wire.h>
#include "powerTest100.h"
#include "30Neurons.h"
#include <Arduino_LSM9DS1.h>
#include <TensorFlowLite.h>
#include <tensorflow/lite/micro/all_ops_resolver.h>
#include <tensorflow/lite/micro/micro_error_reporter.h>
#include <tensorflow/lite/micro/micro_interpreter.h>
#include <tensorflow/lite/schema/schema_generated.h>
#include <tensorflow/lite/version.h>
// global variables used for TensorFlow Lite (Micro)
tflite::MicroErrorReporter tflErrorReporter;
// pull in all the TFLM ops, you can remove this line and
// only pull in the TFLM ops you need, if would like to reduce
// the compiled size of the sketch.
tflite::AllOpsResolver tflOpsResolver;
const tflite::Model* tflModel = nullptr;
tflite::MicroInterpreter* tflInterpreter = nullptr;
TfLiteTensor* tflInputTensor = nullptr;
TfLiteTensor* tflOutputTensor = nullptr;
// Create a static memory buffer for TFLM, the size may need to
// be adjusted based on the model you are using
constexpr int tensorArenaSize = 8 * 1024;
byte tensorArena[tensorArenaSize];
//byte tensorArena[tensorArenaSize] __attribute__((aligned(16)));
#define slaveAddress 0x50  //you have to assign an 8-bit address to Slave
byte dataArraySend[10];
byte dataArrayReceive[10];
int phaseNum = 0;
int powerNum = 0;
float phaseArray[10];
float powerArray[10];
bool transOn = true;
bool secondTime = false;
int dataNum = 10;
  Wire.begin(slaveAddress);                 // join i2c bus with address #50
  Wire.onReceive(receiveEvent);
  Wire.onRequest(requestEvent); // register event
  // get the TFL representation of the model byte array
  tflModel = tflite::GetModel(model);
  if (tflModel->version() != TFLITE_SCHEMA_VERSION) {
    Serial.println("Model schema mismatch!");
    while (1);
  // Create an interpreter to run the model
  tflInterpreter = new tflite::MicroInterpreter(tflModel, tflOpsResolver, tensorArena, tensorArenaSize, &tflErrorReporter);
  // Allocate memory for the model's input and output tensors
  tflInterpreter->AllocateTensors();
  // Get pointers for the model's input and output tensors
  tflInputTensor = tflInterpreter->input(0);
  tflOutputTensor = tflInterpreter->output(0);
  delay(100);
// function that executes whenever data is requested by master
// this function is registered as an event, see setup()
void requestEvent() {
  if (transOn == true)
    // Get required power information
    // Input power to tensorflow model
    for(int i=0; i<10; i++)
//      powerArray[i] = powerSet[powerNum*10+i];
      powerArray[i] = powerSet[i];
      tflInputTensor->data.f[i] = powerArray[i];
    //Run inferencing
    if (invokeStatus != kTfLiteOk) {
      Serial.println("Invoke failed!");
      while (1);
      return;
      phaseArray[i] = tflOutputTensor->data.f[i];
      dataArraySend[i] = int ((phaseArray[i]+23)*5.54348);
      if (dataArraySend[i]>255)
        dataArraySend[i] = 255;
      else if(dataArraySend[i]<=0)
        dataArraySend[i] = 0;
    Serial.print(powerArray[9]);
    Serial.print(" ");
    Serial.println(phaseArray[9]);
    // Send two times to make sure DSP receive the right data
    if (secondTime == true)
      powerNum++;
      secondTime = false;
    else if (secondTime == false)
      secondTime = true;
    // Stop sending data when 100 data sets are completed sent
    if (powerNum == 100)
//      transOn = false;
      powerNum = 0;
    Serial.print("Data Sent: ");
    for(int i=0; i<dataNum; i++)
      Wire.write(dataArraySend[i]);
      Serial.print(dataArraySend[i]);
      Serial.print(" ");
    Serial.println(" ");
      Serial.print("Phase Predicted: ");
        Serial.print(phaseArray[i]);
        Serial.print(" ");
   delay(100);
void receiveEvent(int howMany)
  int nth = 0;
  Serial.print("Data Received: ");
  while(Wire.available()) // loop through all but the last
    int x = Wire.read();    // receive byte as an integer
    dataArrayReceive[nth] = x;
    nth++;
    Serial.print(x);         // print the integer
    Serial.print(" ");         // print the integer
