Nano 33 BLE Sense not detected via USB (even after 2-click RESET trick)
Almost all boards are PRE-LOADED with the BLINK example sketch so an LED should be flashing about 1 second intervals.
You did remove the antistatic foam before use ?
Is your USB cable both power AND DATA or just power ?
It needs to be BOTH.
