My Arduino Nano 33 BLE Sense is not working suddenly. The board isn’t showing up in the IDE’s port section. The port is grayed out.
Here are some of the things I tried onboard:
Double pressing reset button on the board didn’t make a response. (No flashing LED)
I’ve connected a led to the 3V pin of the board, luckily it turned ON. The board’s 3v, 5v, Vin all has output.
Changed the USB cable. Also connected to different USB ports of the pc, that didn’t work either.
Exactly when my board stopped working?
While I was working on ML projects using Edge Impulse, I’ve flashed their firmware to get the data from the board and it working like a charm for an hour. After sometime in idle, it got disconnected. And from that moment my board stopped working.
Physical condition of the board?
It’s brand new and I’ve used it for learning purpose.
I’ve also connected my other boards to the pc: Arduino Uno, Nano, etc. It’s all working and recognized. Not sure what’s the problem with this board. Maybe the bootloader got corrupted?
IDE version: 1.8.13
Mbed OS Standalone Package version: 2.5.2
