I wrote some code to play with the accelerometer over BLE. When I upload the code, it runs just like it should. If I unplug the board from the USB cable, and then power it up with an external lab power supply, I am at 6V right now, the code does not work as the BLE signal does not show up. But if I plug the power supply in and connect the USB in the BLE signal shows up, and stays running even after I remove the USB cable.
Hello jbdww,
Could you please upload the code you are using with the code tags (accessed with the button that looks like this: </> ) or as an attachment.
It sounds like you might have a line of code that is something like:
while(!Serial);
If you have this your code is paused waiting for the serial USB to connect whereas once it is connected it will work fine.
Hope that helps,
Matt
LOL. I found that in the code, and came back here to say never mind. Problem solved.
