Hi, I was trying to understand something more about the nano 33, I read some posts related to my question but I couldn't get a clear answer.
The question is, once connected to an app can I send commands to another board via serial? I was able to use the nano 33 to perform actions via bluetooth but I would need to manage a board that has more pins.
For example app sends '1' to nano33 which sends '1' to arduino mega which performs an action.
Would this be possible? if yes could you show me the sample sketches for both boards?
thanks for the answer, but can I create a serial link like I did with a normal nano? (softwareSerial?) I saw that you can use rx and tx of the nano33 (Serial1) but if I do, the bluetooth no longer works
ok i just saw that it is not necessary to create a software serial (also you cannot)
because you can use different pins as serial hardware, I should try so to not occupy the bluetooth communication right?
Hi Klaus, let me tell you that I really appreciate your interventions, in the past I have read some posts that have saved me from situations that I really couldn't solve! thank you! some of my friends call me genius .. but I think you are a genius! back to us, it is IoT ... this board has complicated my work a bit, my sketch is a mess, but I managed to do everything, I would use the IoT as main board, which receives commands via bluetooth and them sends to a mega via serial (hardware serial on IoT and SoftwareSerial on mega) and the mega performs many actions. If I tried to do it using Serial1 instead on Hardware Serial, the BLE was no longer detected by my smartphone ... if you tell me so, I will try to rewrite the sketch in that way and maybe I will try to use a DFPlayer on Serial1 to see if the same thing .. I don't need it but I want the truth
Hi Klaus, in this sketch (which if I'm not mistaken I took it from you) I try to test some bluetooth commands, when "value" is read, in this case '1' the BLE LED turns off, so it works. The problem is that if I try to add another command for example:
else if (command = 2) {something}
this does not happen, even if in the serial monitor there is a difference between the reading of the different values .. if I send 1 1 is read, if I send 2 2 is read, yet it seems that there is a conflict between the different actions that should be performed.
can you show me how you would add commands to the sketch i sent by adding a second command? and could you explain to me why it doesn't work this way?
Do you know what the beautiful thing is? that I have already worked with a very similar project with classic bluetooth, I had also seen the difference of the double = but I was so taken by the infamous Characteristics that I did not think about the simplest thing. you never stop learning by working with Aduino ... thanks to all guys.
