I am using a Nano 33 iot to save sensor data, get setpoints, and get a current timestamp from a MySQL db. I am using this mysql_connector library
The program functions perfectly for hours, but will eventually hang on one of the executes (it can hang on any one of them). It will hang here for hours on end; eventually it will unstick itself & resume operation. Repeat everything a few hours later.
This makes me think it is not a memory issue but something wrong with the execute. What can I do to make it not hang here?
code below
//Common Libraries
#include <SPI.h>
#include <WiFiNINA.h>
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
#include <avr/dtostrf.h>
#include "secret.h"
//Node Libraries
#include <DHT.h>
#define O_UPPER 9
#define O_LOWER 10
//Wifi
byte mac_addr[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //Do I need this?
char ssid[] = SECRET_SSID;
char pass[] = SECRET_PASS;
int status = WL_IDLE_STATUS;
int keyIndex = 0;
WiFiClient client;
//MySQL
IPAddress server_addr(192, 168, 1, 133);
#define port 3306
char db[] = SECRET_MYSQL_DB;
char user[] = SECRET_MYSQL_USER;
char password[] = SECRET_MYSQL_PASS;
char query[250];
char tempStr[6], columnStr[150], dataStr[50];
char DATA_QUERY[] = "INSERT INTO canna1_data (%s) VALUES (%s);";
char SP_QUERY[] = "SELECT * FROM canna1_sp ORDER BY id DESC LIMIT 1;";
char TIME_QUERY[] = "SELECT * FROM canna1_data ORDER BY id DESC LIMIT 1;";
byte dbUpdateRate = 30, dbCheckRate = 5;
uint32_t dbCheckTimer;
uint32_t dbUpdateTimer;
MySQL_Connection conn((Client *)&client);
//Node Specific
bool daytime, lights, fan;
char lightsSP[5], fanSP[5];
byte dateTime = 0, sunrise = 7, sunset = 19;
int soilMoisture;
float temptemp;
DHT exhaust(6, DHT11);
DHT intake(7, DHT11);
DHT room(8, DHT11);
while (status != WL_CONNECTED) {
digitalWrite(LED_BUILTIN, HIGH);
delay(100);
status = WiFi.begin(ssid, pass);
digitalWrite(LED_BUILTIN, LOW);
exhaust.begin();
intake.begin();
room.begin();
pinMode(O_UPPER, OUTPUT);
pinMode(O_LOWER, OUTPUT);
digitalWrite(O_UPPER, LOW);
digitalWrite(O_LOWER, LOW);
while(!conn.connect(server_addr, port, user, password, db)) {
delay(100);
dbUpdate();
dbCheck();
conn.close();
dbCheckTimer = millis();
dbUpdateTimer = millis();
if (millis() - dbCheckTimer >= (dbCheckRate * 1000)) {
if (conn.connect(server_addr, port, user, password, db)) {
dbCheck();
if (millis() - dbUpdateTimer >= (dbUpdateRate * 1000)) {
Serial.println("Update");
dbUpdate();
else Serial.println("Conn Failed.");
conn.close();
//------------------------------------MySql Functions-------------------------
void dbCheck() {
MySQL_Cursor *cur = new MySQL_Cursor(&conn);
row_values *row = NULL;
cur->execute(TIME_QUERY);
Serial.println("Fail Check 0.5");
cur->get_columns();
do {
Serial.println("Fail Check 1");
row = cur->get_next_row();
Serial.println("Fail Check 2");
if (row != NULL) {
Serial.println("Fail Check 3");
dateTime = (row->values[1][11] - 48) * 10 + (row->values[1][12] - 48);
} while (row != NULL);
Serial.println("Fail Check 4");
cur->execute(SP_QUERY);
Serial.println("Fail Check 4.5");
cur->get_columns();
do {
Serial.println("Fail Check 5");
Serial.println("Fail Check 6");
if (row != NULL) {
strcpy(lightsSP, row->values[2]);
strcpy(fanSP, row->values[3]);
sunrise = atol(row->values[12]);
sunset = atol(row->values[13]);
if (sunrise <= dateTime && dateTime < sunset) {
if (sunrise < sunset) daytime = true;
else daytime = false;
else {
if (sunrise < sunset) daytime = false;
else daytime = true;
Serial.println("Fail Check 7");
if (strcmp(lightsSP, "NULL") != 0) {
if (strcmp(lightsSP, "1") == 0) {
digitalWrite(O_UPPER, HIGH);
lights = 1;
else {
lights = 0;
else {
if (daytime) {
lights = 1;
else {
lights = 0;
delete cur;
void dbUpdate() {
strcpy(columnStr, "lights,fan");
dataStr[0] = lights + 48;
dataStr[1] = ',';
dataStr[2] = fan + 48;
dataStr[3] = '\0';
temptemp = intake.readTemperature();
if (!isnan(temptemp)) {
dtostrf(temptemp, 4, 2, tempStr);
strcat(columnStr, ",intakeT");
strcat(dataStr, ",");
strcat(dataStr, tempStr);
temptemp = intake.readHumidity();
strcat(columnStr, ",intakeH");
temptemp = room.readTemperature();
strcat(columnStr, ",roomT");
temptemp = room.readHumidity();
strcat(columnStr, ",roomH");
temptemp = exhaust.readTemperature();
strcat(columnStr, ",exhaustT");
temptemp = exhaust.readHumidity();
strcat(columnStr, ",exhaustH");
Serial.println("Fail Check 9");
sprintf(query, DATA_QUERY, columnStr, dataStr);
cur->execute(query);
memset(columnStr, 0, sizeof(columnStr));
memset(dataStr, 0, sizeof(dataStr));
delete cur;
Serial.println("Fail Check 10");
