Nano 33 IoT LedController and LED programs
Hello! I am a high school student. This is my first project using Arduino and BLE, but it did not work. To accomplish a simple example using a button on one Arduino and a LED on another, I used the provided sketch example codes: LedControl (under: File > Examples > ArduinoBLE > Central > LedControl) and LED (under: File > Examples > ArduinoBLE > Peripheral > LED) on the Arduino Software. For my circuitry, I used 2 Arduino Nano 33 IoT and a 5k olm pull-up resistor with a button.
Here is the LedControl code:
  LED Control
  This example scans for BLE peripherals until one with the advertised service
  "19b10000-e8f2-537e-4f6c-d104768a1214" UUID is found. Once discovered and connected,
  it will remotely control the BLE Peripheral's LED, when the button is pressed or released.
  The circuit:
  - Arduino MKR WiFi 1010, Arduino Uno WiFi Rev2 board, Arduino Nano 33 IoT,
    Arduino Nano 33 BLE, or Arduino Nano 33 BLE Sense board.
  - Button with pull-up resistor connected to pin 2.
  You can use it with another board that is compatible with this library and the
  Peripherals -> LED example.
  This example code is in the public domain.
#include <ArduinoBLE.h>
// variables for button
const int buttonPin = 2;
int oldButtonState = LOW;
  while (!Serial);
  // configure the button pin as input
  pinMode(buttonPin, INPUT);
  // initialize the BLE hardware
  BLE.begin();
  Serial.println("BLE Central - LED control");
  // start scanning for peripherals
  BLE.scanForUuid("19b10000-e8f2-537e-4f6c-d104768a1214");
  // check if a peripheral has been discovered
  BLEDevice peripheral = BLE.available();
  if (peripheral) {
    // discovered a peripheral, print out address, local name, and advertised service
    Serial.print("Found ");
    Serial.print(peripheral.address());
    Serial.print(" '");
    Serial.print(peripheral.localName());
    Serial.print("' ");
    Serial.print(peripheral.advertisedServiceUuid());
    if (peripheral.localName() != "LED") {
      return;
    // stop scanning
    BLE.stopScan();
    controlLed(peripheral);
    // peripheral disconnected, start scanning again
void controlLed(BLEDevice peripheral) {
  // connect to the peripheral
  Serial.println("Connecting ...");
  if (peripheral.connect()) {
    Serial.println("Connected");
    Serial.println("Failed to connect!");
    return;
  // discover peripheral attributes
  Serial.println("Discovering attributes ...");
  if (peripheral.discoverAttributes()) {
    Serial.println("Attributes discovered");
    Serial.println("Attribute discovery failed!");
    peripheral.disconnect();
    return;
  // retrieve the LED characteristic
  BLECharacteristic ledCharacteristic = peripheral.characteristic("19b10001-e8f2-537e-4f6c-d104768a1214");
  if (!ledCharacteristic) {
    Serial.println("Peripheral does not have LED characteristic!");
    return;
  } else if (!ledCharacteristic.canWrite()) {
    Serial.println("Peripheral does not have a writable LED characteristic!");
    return;
  while (peripheral.connected()) {
    // while the peripheral is connected
    // read the button pin
    int buttonState = digitalRead(buttonPin);
    if (oldButtonState != buttonState) {
      // button changed
      oldButtonState = buttonState;
      if (buttonState) {
        Serial.println("button pressed");
        // button is pressed, write 0x01 to turn the LED on
        ledCharacteristic.writeValue((byte)0x01);
        Serial.println("button released");
        // button is released, write 0x00 to turn the LED off
        ledCharacteristic.writeValue((byte)0x00);
  Serial.println("Peripheral disconnected");
Here is the LED code:
  LED
  This example creates a BLE peripheral with service that contains a
  characteristic to control an LED.
  The circuit:
  You can use a generic BLE central app, like LightBlue (iOS and Android) or
  nRF Connect (Android), to interact with the services and characteristics
  created in this sketch.
BLEService ledService("19B10000-E8F2-537E-4F6C-D104768A1214"); // BLE LED Service
// BLE LED Switch Characteristic - custom 128-bit UUID, read and writable by central
BLEByteCharacteristic switchCharacteristic("19B10001-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite);
const int ledPin = LED_BUILTIN; // pin to use for the LED
  while (!Serial);
  // set LED pin to output mode
  pinMode(ledPin, OUTPUT);
  // begin initialization
  if (!BLE.begin()) {
    Serial.println("starting BLE failed!");
    while (1);
  // set advertised local name and service UUID:
  BLE.setLocalName("LED");
  BLE.setAdvertisedService(ledService);
  // add the characteristic to the service
  ledService.addCharacteristic(switchCharacteristic);
  // add service
  BLE.addService(ledService);
  // set the initial value for the characeristic:
  switchCharacteristic.writeValue(0);
  // start advertising
  BLE.advertise();
  Serial.println("BLE LED Peripheral");
  // listen for BLE peripherals to connect:
  BLEDevice central = BLE.central();
  // if a central is connected to peripheral:
  if (central) {
    Serial.print("Connected to central: ");
    // print the central's MAC address:
    Serial.println(central.address());
    // while the central is still connected to peripheral:
    while (central.connected()) {
      // if the remote device wrote to the characteristic,
      // use the value to control the LED:
      if (switchCharacteristic.written()) {
        if (switchCharacteristic.value()) {   // any value other than 0
          Serial.println("LED on");
          digitalWrite(ledPin, HIGH);         // will turn the LED on
        } else {                              // a 0 value
          Serial.println(F("LED off"));
          digitalWrite(ledPin, LOW);          // will turn the LED off
    // when the central disconnects, print it out:
    Serial.print(F("Disconnected from central: "));
Here is the error message I received when I deployed both codes:
Found 24:62:ab:b2:43:2a 'LED' 19b10000-e8f2-537e-4f6c-d104768a1214
Connecting ...
Failed to connect!
Does anyone know how to fix this? Thank you for your help!
Welcome to the forum
With BLE it is a good idea to test one Arduino sketch at a time. I recommend you use a generic BLE app on your smartphone and make sure you can connect to your peripheral BLE device first. I use BLE Scanner on iOS but there are many others on iOS and Android.
Program the LED sketch into both boards (only one active at a time) and see whether the behave the same. The sketch looks OK. I did not have time to test it.
Did you look at the print from the LED sketch? If not disable the while(!Serial) to ensure the LED sketch runs.
Another recommendation is to use defines for your UUIDs and use these in your code. For larger project I would even place them in header file to include them in the peripheral and client. e.g.
#define BLE_UUID_MY_SERVICE "1234 ..."
#define BLE_UUID_MY_CHARACTERSITIC "5678..."
