Hey,
I was trying to use a Nano 33 IoT and it had all my WiFi credentials in and all the stuff you need to do and I uploaded the sketch and I went to the serial monitor and it says its connected to the Cloud but the device never go "online" in the devices menu and OTAs is not a option and the same sketch works fine with my Nano RP2040 Connect, I can do OTAs and the device gos online.
Hi all,
I'm having trouble getting my Nano 33 IoT to connect to the Arduino Cloud. I've gone through the setup process in the Arduino IoT Cloud interface, and the device is detected, but when I try to upload the sketch and connect, it keeps failing to connect to the network/cloud.
Here's what I’ve tried so far:
Verified my Wi-Fi credentials (2.4GHz network, not 5GHz)
Updated the firmware using the "Firmware Updater" in Arduino IDE
Installed the latest version of the "Arduino SAMD Boards" and "WiFiNINA" libraries
Checked that my board is listed correctly under Devices in Arduino Cloud
Tried uploading example sketches like ConnectWithWPA from the WiFiNINA examples – connection still fails
Use chrome browser and delete the board as device. Once the agent is running, re-attach it as a device.
Make sure that your wifi network credential "password" is not too long or have special characters. Suggestion: Create a simple 2.4Ghz hotspot with your phone to test.
