Hello,
I am trying to reassign interrupts to D4 and D5 inputs by modifying ~/Library/Arduino15/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot/variant.cpp (as suggested at Befuddled about interrupts and pin assignments)
I want to use EXTERNAL_INT_4 and EXTERNAL_INT_5 from pins D9 and D10 (where I do not need them)
here is a modified fragment of variant.cpp
// 0/1 - SERCOM/UART
{ PORTB, 23, PIO_SERCOM_ALT, (PIN_ATTR_DIGITAL ), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_NONE }, // RX: SERCOM5/PAD[3]
{ PORTB, 22, PIO_SERCOM_ALT, (PIN_ATTR_DIGITAL ), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_NONE }, // TX: SERCOM5/PAD[2]
// 2..7
// Digital Low
{ PORTB, 10, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM|PIN_ATTR_TIMER ), No_ADC_Channel, PWM5_CH0, TC5_CH0, EXTERNAL_INT_10 },
{ PORTB, 11, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM|PIN_ATTR_TIMER ), No_ADC_Channel, PWM5_CH1, TC5_CH1, EXTERNAL_INT_11 },
// *** { PORTA, 7, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM|PIN_ATTR_TIMER ), ADC_Channel7, PWM1_CH1, TCC1_CH1, EXTERNAL_INT_NONE }, //*** orig
// *** { PORTA, 5, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM|PIN_ATTR_TIMER ), ADC_Channel5, PWM0_CH1, TCC0_CH1, EXTERNAL_INT_NONE }, //*** orig
{ PORTA, 7, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM|PIN_ATTR_TIMER ), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_4 }, //*** <<< modified
{ PORTA, 5, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM|PIN_ATTR_TIMER ), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_5 }, //*** <<< modified
{ PORTA, 4, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM|PIN_ATTR_TIMER ), ADC_Channel4, PWM0_CH0, TCC0_CH0, EXTERNAL_INT_NONE },
{ PORTA, 6, PIO_DIGITAL, (PIN_ATTR_DIGITAL ), ADC_Channel6, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_NONE },
// 8..12
// Digital High
{ PORTA, 18, PIO_DIGITAL, (PIN_ATTR_DIGITAL ), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_NONE },
// *** { PORTA, 20, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM|PIN_ATTR_TIMER_ALT), No_ADC_Channel, PWM0_CH6, TCC0_CH6, EXTERNAL_INT_4 }, //*** orig
// *** { PORTA, 21, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM|PIN_ATTR_TIMER_ALT), No_ADC_Channel, PWM0_CH7, TCC0_CH7, EXTERNAL_INT_5 }, //*** orig
{ PORTA, 20, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM|PIN_ATTR_TIMER_ALT), No_ADC_Channel, PWM0_CH6, TCC0_CH6, EXTERNAL_INT_NONE }, // *** <<< modified
{ PORTA, 21, PIO_DIGITAL, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM|PIN_ATTR_TIMER_ALT), No_ADC_Channel, PWM0_CH7, TCC0_CH7, EXTERNAL_INT_NONE }, // *** <<< modified
{ PORTA, 16, PIO_SERCOM, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM|PIN_ATTR_TIMER ), No_ADC_Channel, PWM2_CH0, TCC2_CH0, EXTERNAL_INT_0 }, // MOSI: SERCOM1/PAD[0]
{ PORTA, 19, PIO_SERCOM, (PIN_ATTR_DIGITAL|PIN_ATTR_PWM|PIN_ATTR_TIMER ), No_ADC_Channel, PWM3_CH1, TC3_CH1, EXTERNAL_INT_NONE }, // MISO: SERCOM1/PAD[3]
// 13 (LED)
{ PORTA, 17, PIO_SERCOM, (PIN_ATTR_DIGITAL ), No_ADC_Channel, NOT_ON_PWM, NOT_ON_TIMER, EXTERNAL_INT_1 }, // SCK: SERCOM1/PAD[1]
.. however the ext_int_4 does not work for me on pin D4. Where is the problem?
thanks
JS
