Hello,
The forum post which discussed using the power scheme in my schematic originates here: Check out what eetech00 said at post #12
This code comes from Nuts and Volts website but originated from tinker.it as sighted below.
The only changes I made so far were to omit the DIP switch for digital pins D9-D12, I omitted pots at A4 and A5 so that I could use I2C SDA and SCL. *And I changed the way the Nano and board peripherals are powered.
// AUDUINO - MIDI Upgrade v1.1
// For Arduino NANO
// MIDI programming by Notes and Volts http://www.notesandvolts.com
// Tutorial - http://www.notesandvolts.com/2015/05/auduino-synth-midi.html
// ** Requires Arduino MIDI Library v4.2 or later **
// Based on the Auduino Synthesizer v5 by Peter Knight http://tinker.it
// Version 1.0 - Initial release
// Version 1.1 - Fixed bug that caused note to hang with some DAWs
#include <avr/io.h>
#include <avr/interrupt.h>
#include <MIDI.h> // Requires Arduino MIDI Library v4.2 or later
// *** MIDI Parameters ***********************************************************
#define BENDRANGE 12 // Change to set Number of Semitones for Pitch Bend (1 to 24)
// If the DIP Switch option is installed - set dipSwitchInstalled to "true"
const bool dipSwitchInstalled = false;
// DIP Switch Setting = Channel (1=ON, 0=OFF)
// 0000 = 1 0001 = 2 0010 = 3 0011 = 4
// 0100 = 5 0101 = 6 0110 = 7 0111 = 8
// 1000 = 9 1001 = 10 1010 = 11 1011 = 12
// 1100 = 13 1101 = 14 1110 = 15 1111 = 16
// If DIP Switch is NOT installed - change dipSwitchInstalled to "false"
// If dipSwitchInstalled is set to false, the MIDI channel will be set
// to the value of MIDICHANNEL
#define MIDICHANNEL 1 // Can be a value from 1 to 16
MIDI_CREATE_DEFAULT_INSTANCE();
uint16_t syncPhaseAcc;
uint16_t syncPhaseInc;
uint16_t grainPhaseAcc;
uint16_t grainPhaseInc;
uint16_t grainAmp;
uint8_t grainDecay;
uint16_t grain2PhaseAcc;
uint16_t grain2PhaseInc;
uint16_t grain2Amp;
uint8_t grain2Decay;
// DIP Switch Pins
#define DIP_SW1 9
#define DIP_SW2 10
#define DIP_SW3 11
#define DIP_SW4 12
// Map Analogue channels
#define SYNC_CONTROL (4)
#define GRAIN_FREQ_CONTROL (0)
#define GRAIN_DECAY_CONTROL (2)
#define GRAIN2_FREQ_CONTROL (3)
#define GRAIN2_DECAY_CONTROL (1)
#define BUFFER 8 //Size of keyboard buffer
#if defined(__AVR_ATmega8__)
// On old ATmega8 boards.
// Output is on pin 11
#define LED_PIN 13
#define LED_PORT PORTB
#define LED_BIT 5
#define PWM_PIN 11
#define PWM_VALUE OCR2
#define PWM_INTERRUPT TIMER2_OVF_vect
#elif defined(__AVR_ATmega1280__)
// On the Arduino Mega
// Output is on pin 3
#define LED_PIN 13
#define LED_BIT 7
#define PWM_PIN 3
#define PWM_VALUE OCR3C
#define PWM_INTERRUPT TIMER3_OVF_vect
#else
// For modern ATmega168 and ATmega328 boards
#define PWM_PIN 3
#define PWM_VALUE OCR2B
#define LED_PIN 13
#define LED_BIT 5
#endif
// Smooth logarithmic mapping
uint16_t antilogTable[] = {
64830, 64132, 63441, 62757, 62081, 61413, 60751, 60097, 59449, 58809, 58176, 57549, 56929, 56316, 55709, 55109,
54515, 53928, 53347, 52773, 52204, 51642, 51085, 50535, 49991, 49452, 48920, 48393, 47871, 47356, 46846, 46341,
45842, 45348, 44859, 44376, 43898, 43425, 42958, 42495, 42037, 41584, 41136, 40693, 40255, 39821, 39392, 38968,
38548, 38133, 37722, 37316, 36914, 36516, 36123, 35734, 35349, 34968, 34591, 34219, 33850, 33486, 33125, 32768
uint16_t mapPhaseInc(uint16_t input) {
return (antilogTable[input & 0x3f]) >> (input >> 6);
// Stepped chromatic mapping
uint16_t midiTable[] = {
0, 18, 19, 20, 22, 23, 24, 26, 27, 29, 31, 32, 34, 36, 38, 41, 43, 46, 48, 51, 54, 58, 61, 65, 69, 73,
77, 82, 86, 92, 97, 103, 109, 115, 122, 129, 137, 145, 154, 163, 173, 183, 194, 206, 218, 231,
244, 259, 274, 291, 308, 326, 346, 366, 388, 411, 435, 461, 489, 518, 549, 581, 616, 652, 691,
732, 776, 822, 871, 923, 978, 1036, 1097, 1163, 1232, 1305, 1383, 1465, 1552, 1644, 1742,
1845, 1955, 2071, 2195, 2325, 2463, 2610, 2765, 2930, 3104, 3288, 3484, 3691, 3910, 4143,
4389, 4650, 4927, 5220, 5530, 5859, 6207, 6577, 6968, 7382, 7821, 8286, 8779, 9301, 9854,
10440, 11060, 11718, 12415, 13153, 13935, 14764, 15642, 16572, 17557, 18601, 19708, 20879,
22121, 23436, 24830, 26306
uint16_t mapMidi(uint16_t input) {
return (midiTable[input]);
// Stepped Pentatonic mapping
uint16_t pentatonicTable[54] = {
0, 19, 22, 26, 29, 32, 38, 43, 51, 58, 65, 77, 86, 103, 115, 129, 154, 173, 206, 231, 259, 308, 346,
411, 461, 518, 616, 691, 822, 923, 1036, 1232, 1383, 1644, 1845, 2071, 2463, 2765, 3288,
3691, 4143, 4927, 5530, 6577, 7382, 8286, 9854, 11060, 13153, 14764, 16572, 19708, 22121, 26306
uint16_t mapPentatonic(uint16_t input) {
uint8_t value = (1023 - input) / (1024 / 53);
return (pentatonicTable[value]);
//Global Varibles used by MIDI Upgrade
byte note = 0;
byte buff[BUFFER];
byte buffersize = 0;
float bendfactor = ((BENDRANGE * 100.0) / 8190.0);
float cents = 0;
bool pot = false;
bool noteOn = false;
int oldpot = 0;
int transpose = 0;
void audioOn() {
// ATmega8 has different registers
TCCR2 = _BV(WGM20) | _BV(COM21) | _BV(CS20);
TIMSK = _BV(TOIE2);
TCCR3A = _BV(COM3C1) | _BV(WGM30);
TCCR3B = _BV(CS30);
TIMSK3 = _BV(TOIE3);
#else
// Set up PWM to 31.25kHz, phase accurate
TCCR2A = _BV(COM2B1) | _BV(WGM20);
TCCR2B = _BV(CS20);
TIMSK2 = _BV(TOIE2);
#endif
if (dipSwitchInstalled) {
pinMode(DIP_SW1, INPUT_PULLUP);
pinMode(DIP_SW2, INPUT_PULLUP);
pinMode(DIP_SW3, INPUT_PULLUP);
pinMode(DIP_SW4, INPUT_PULLUP);
pinMode(PWM_PIN, OUTPUT);
audioOn();
pinMode(LED_PIN, OUTPUT);
oldpot = analogRead(SYNC_CONTROL);
MIDI.begin(DipSwitch());
else {
MIDI.begin(MIDICHANNEL);
MIDI.setHandleNoteOn(NoteOnMidi);
MIDI.setHandleNoteOff(NoteOffMidi);
MIDI.setHandlePitchBend(Pitchbend);
void loop() { // *** MAIN LOOP ***
MIDI.read();
if (abs(analogRead(SYNC_CONTROL) - oldpot) > 5) pot = true;// Check if SYNC Pot has been touched
// If Sync pot has been touched - Play pentatonic major scale with Root Note set by note on keyboard
if (pot == true && noteOn == true) {
syncPhaseInc = (mapPentatonic(analogRead(SYNC_CONTROL)) * pow(2, ((cents + transpose) / 1200)) );
// If Sync pot has not been touched - Play the note sent by keyboard
else {
syncPhaseInc = mapMidi(note) * pow(2, (cents / 1200));
grainPhaseInc = mapPhaseInc(analogRead(GRAIN_FREQ_CONTROL)) / 2;
grainDecay = analogRead(GRAIN_DECAY_CONTROL) / 8;
grain2PhaseInc = mapPhaseInc(analogRead(GRAIN2_FREQ_CONTROL)) / 2;
grain2Decay = analogRead(GRAIN2_DECAY_CONTROL) / 4;
SIGNAL(PWM_INTERRUPT)
uint8_t value;
uint16_t output;
syncPhaseAcc += syncPhaseInc;
if (syncPhaseAcc < syncPhaseInc) {
// Time to start the next grain
grainPhaseAcc = 0;
grainAmp = 0x7fff;
grain2PhaseAcc = 0;
grain2Amp = 0x7fff;
LED_PORT ^= 1 << LED_BIT; // Faster than using digitalWrite
// Increment the phase of the grain oscillators
grainPhaseAcc += grainPhaseInc;
grain2PhaseAcc += grain2PhaseInc;
// Convert phase into a triangle wave
value = (grainPhaseAcc >> 7) & 0xff;
if (grainPhaseAcc & 0x8000) value = ~value;
// Multiply by current grain amplitude to get sample
output = value * (grainAmp >> 8);
// Repeat for second grain
value = (grain2PhaseAcc >> 7) & 0xff;
if (grain2PhaseAcc & 0x8000) value = ~value;
output += value * (grain2Amp >> 8);
// Make the grain amplitudes decay by a factor every sample (exponential decay)
grainAmp -= (grainAmp >> 8) * grainDecay;
grain2Amp -= (grain2Amp >> 8) * grain2Decay;
// Scale output to the available range, clipping if necessary
output >>= 9;
if (output > 255) output = 255;
// Output to PWM (this is faster than using analogWrite)
PWM_VALUE = output;
// NoteOnMidi function is called when a Note On event is detected
// Put note in key buffer and set note variable
void NoteOnMidi(byte channel, byte pitch, byte velocity) {
if (buffersize < BUFFER) {
note = pitch;
buff[buffersize] = pitch;
buffersize++;
noteOn = true;
// Set root note of Pentatonic scale
int offset = pitch % 12;
if (offset < 7) transpose = (5 + offset) * 100;
else if (offset >= 7) transpose = (offset - 7) * 100;
// NoteOffMidi function is called when a Note Off event is detected
// If there are other notes in the key buffer (more than one key held)
// re-trigger old note. If key buffer is empty - set note to zero (off).
void NoteOffMidi(byte channel, byte pitch, byte velocity) {
if (buffersize > 1) {
for (int ctr = 0; ctr < buffersize; ctr++) {
if (buff[ctr] == pitch) {
ShiftLeft(ctr + 1);
note = buff[buffersize - 1];
int offset = note % 12;
else {
note = 0;
noteOn = false;
buff[buffersize - 1] = 0;
buffersize = 0;
pot = false;
// ShiftLeft closes gap in key buffer when note is removed.
void ShiftLeft(int index) {
int ctr = (index - 1);
for (ctr; ctr < buffersize - 1; ctr++) {
buff[ctr] = buff[ctr + 1];
buff[ctr + 1] = 0;
buffersize--;
// Pitchbend function is called when Pitchbend data is received.
// This function coverts the Pitchbend number into cents (100 cents = 1 semitone)
// In the main loop, the frequency of the note plus the pitchbend is calculated
// using this formula: Final Frequency = note * 2^(cents/1200)
void Pitchbend (byte channel, int bend) {
cents = bend * bendfactor;
byte DipSwitch() {
byte value = 0;
if (digitalRead(DIP_SW4) == LOW)
value += 1;
if (digitalRead(DIP_SW3) == LOW)
value += 2;
if (digitalRead(DIP_SW2) == LOW)
value += 4;
if (digitalRead(DIP_SW1) == LOW)
value += 8;
return (value + 1);
My updated schematic. Changed the audio output volume pot.
