I got the following code to compile and uploaded on a nicla sense me:
#include <mbed.h>
#include <BLE.h>
using namespace mbed;
DigitalOut led(LED1);
/*------------GLOBAL VARIABLES-------------*/
const static char DEVICE_NAME[] = "NiclaLongRange"; // Device name when detected on Bluetooth
static events::EventQueue event_queue(10 * EVENTS_EVENT_SIZE); // Create Event queue
static const uint16_t MAX_ADVERTISING_PAYLOAD_SIZE = 59; // Advertising payload parameter
const ble::phy_set_t CodedPHY(ble::phy_t::LE_CODED); // Creating a Coded Phy set
//const ble::phy_set_t OneMPHY(ble::phy_t::LE_1M);
class LRDemo : public ble::Gap::EventHandler {
public:
/* Class constructor */
LRDemo(BLE &ble, events::EventQueue &event_queue) :
_ble(ble), // BLE API Class
_event_queue(event_queue),
_adv_handle(ble::INVALID_ADVERTISING_HANDLE), // Advertising parameter
_adv_data_builder(_adv_buffer) { } // Advertising parameter
/* Class destructor */
~LRDemo() {
if (_ble.hasInitialized()) {
_ble.shutdown();
void start() {
_ble.gap().setEventHandler(this); // Assign GAP events to this class
_ble.init(this, &LRDemo::on_init_complete); // Initialize Bluetooth
_event_queue.dispatch_forever(); // Wait for event forever
private:
/** Callback triggered when the ble initialization process has finished */
void on_init_complete(BLE::InitializationCompleteCallbackContext *params) {
if (params->error != BLE_ERROR_NONE) {
Serial.println("Ble initialization failed.");
return;
Serial.println("Ble initialized.");
/* Create advertising parameters and payload */
ble::AdvertisingParameters adv_parameters(
ble::advertising_type_t::CONNECTABLE_NON_SCANNABLE_UNDIRECTED, // Advertising Type here : connectable non scannable undirected = connectable with extended advertising
//ble::advertising_type_t::CONNECTABLE_DIRECTED_LOW_DUTY, // Advertising Type here : connectable undirected = connectable with extended advertising with legacy PDUs
ble::adv_interval_t(ble::millisecond_t(500)), // Min Advertising time in ms
ble::adv_interval_t(ble::millisecond_t(500)), // Max Advertising time in ms
false // Legacy PDU : Needed to be OFF in Long Range Mode
adv_parameters.setPhy(ble::phy_t::LE_CODED, ble::phy_t::LE_CODED); // Set Advertising radio modulation to LE_CODED Phy (=Long Range)
adv_parameters.setTxPower(8); // Set radio output power to 8dbm (max)
_ble.gap().setPreferredPhys(&CodedPHY, &CodedPHY); // Set preferred connection phy to LE_CODED (=long range)
if (_adv_handle == ble::INVALID_ADVERTISING_HANDLE) { // Create advertising set with parameters defined before
_ble.gap().createAdvertisingSet(
&_adv_handle,
adv_parameters);
_adv_data_builder.clear();
_adv_data_builder.setFlags();
_adv_data_builder.setName(DEVICE_NAME); // Set Bluetooth device name
/* Setup advertising */
_ble.gap().setAdvertisingParameters(_adv_handle, adv_parameters);
_ble.gap().setAdvertisingPayload(_adv_handle, _adv_data_builder.getAdvertisingData());
/* Start advertising */
_ble.gap().startAdvertising(_adv_handle);
Serial.println("Start advertising...");
void onConnectionComplete(const ble::ConnectionCompleteEvent &event) {
Serial.println("Device connected");
void onDisconnectionComplete(const ble::DisconnectionCompleteEvent&) {
Serial.println("Device disconnected");
private:
/* Class variables declaration*/
BLE &_ble;
events::EventQueue &_event_queue;
uint8_t _adv_buffer[MAX_ADVERTISING_PAYLOAD_SIZE]; // Advertising parameters
ble::advertising_handle_t _adv_handle; //
ble::AdvertisingDataBuilder _adv_data_builder; //
/** Schedule processing of events from the BLE middleware in the event queue. */
void schedule_ble_events(BLE::OnEventsToProcessCallbackContext *context) {
event_queue.call(Callback<void()>(&context->ble, &BLE::processEvents));
void setup(){
/* Setup Debugging */
while(!Serial);
Serial.println("Start Nicla1 BLE long range");
/* Low Power */
//digitalWrite(LED_PWR, LOW); // Turn off power LED
//digitalWrite(PIN_ENABLE_SENSORS_3V3, LOW); // Turn off sensors
//NRF_POWER->DCDCEN = 0x00000001; // Enable DCDC
BLE &ble = BLE::Instance(); // Create the BLE object in order to use BLE_API function
ble.onEventsToProcess(schedule_ble_events); // Set event schedule
LRDemo demo(ble, event_queue); // Create LRDemo Object
demo.start(); // Start Bluetooth Long Range
Serial.println ("And advertising ...");
delay(2000);
Following is printed in the serial monitor:
Ble initialized.
Using LightBlue on an iphone 13 i do not see the device, although ble seems to be successfully initialized and adverstising has started. Also tried scanning from an android samsung tablet using nRF Connect app from Nordic: nicla not detected. Any ideas on why this code is not working? Using ArduinoBLE i can easily detect and connect to the nicla from the nano ble and read its sensor values, but the range is very limited.
Arduino IDE version 2.0.3
Arduino mbed os nicla boards 3.5.5
Update: i also tried scanning for the nicla from a nano ble board using the following code:
// include libraries
#include <ArduinoBLE.h>
#include <SPI.h>
#include <avr/dtostrf.h>
// start serial monitor
while (! Serial);
Serial.println("NANO BLE - START SETUP");
// start ble
if (!BLE.begin()) {
Serial.println("* Starting Bluetooth® Low Energy module failed!");
while (1);
BLE.setLocalName("Nano 33 BLE (Central)");
BLE.advertise();
scanForNiclaLongRange();
void loop() { }
void scanForNiclaLongRange(){
BLEDevice niclaLongRange;
Serial.println("- Scanning for Nicla Long Range...");
do
BLE.scanForName("NiclaLongRange");
niclaLongRange = BLE.available();
} while (!niclaLongRange);
if (niclaLongRange) {
Serial.println("- Nicla Long Range found");
Serial.print("* MAC address: ");
Serial.println(niclaLongRange.address());
Serial.print("* Local name: ");
Serial.println(niclaLongRange.localName());
Serial.print("* Advertised service UUID: ");
Serial.println(niclaLongRange.advertisedServiceUuid());
//nicla2.advertised.readings
BLE.stopScan();
//connectToPeripheral(nicla2);
But this also failed to detect the nicla
