Nano BLE Sensor serial wont work....
Before you start with the " read other ..blah blah..." I read it all and tried it all. This thing won't open Serial port since the port changes. reset wont work. Just puts me at square one. Last try to to get this to work before it goes back to Amazon. Disappointed in Arduino for putting this thing out. I have used several other board with no issue. No point in putting up error since everyone knows what its doing. Just hoping someone out there made some break through getting this garbage to work. SMH....
Please don’t forget to link Amazon to this post as proof you will not provide details to get help.
Now in case you DO want help then some of the following will apply.
Please READ THIS POST to help you get the best out of the forum.
SIMPLE TROUBLESHOOTING.
These steps may also save you some unnecessary time and effort in the forum.
COMMON ISSUES
  • Check you have a COMMON GROUND where required.
  • Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
  • Try other computers where possible.
  • Try other USB leads where possible.
  • You may not have the correct driver installed. CH340/341 or CP2102
  • There may be a problem with the board check your wiring first.
  • Remove any items connected to pins 0 and 1.
    COMPUTER RELATED
  • Ensure you turn off any additional security / antivirus just to test.
  • There may be a problem with the PC try RESTARTING it.
  • You may be selecting the wrong COM port.
  • Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
  • Clear your browsers CACHE.
  • Close the IDE before using any other serial programs.
  • Preferably install IDE’s as ADMINISTRATOR or your OS equivalent
    Performing the above actions may help resolve your problem without further help.
Bob.
