I am looking for some very basic suggestions how to accomplish a fairly simple task.
I need to configure a small pull solenoid, which will pull about 15mm when a Switch is activated via bluetooth then release once the switch/button is released. The solenoid will need to be powered via battery.
I have experience working on small electronics/soldering but not robotics specifically. I am not really sure where to start.
So far, my idea is to use a Adriano Nano Every + HC-05 for the button/switch. Then use another Adriano Nano Every + Hc-05 to control the solenoid.
Space is also a big concern, if there is a smaller board or more compact way to do this I would be interested.
What I am also unclear on is the limitations. Ideally the switch/button would be able to run off a coin battery, and the solenoid module would run off a larger 12v pack or something that will last quite a while.
If anyone can point me in the right direction, to similar tutorials or suggestions on what boards could be used it would be greatly appreciated.
The switch and solenoid will only be about 3 feet apart, but must be a wireless connection.
I definitely do not have any code at this point. But the idea would be the solenoid retracts when the button is pushed down, and remains down until button is released.
That part I am still questioning also. I need to figure out how much force will be needed to from the solenoid. I see the Arduino nano boards operate at 5v, but the input can be higher. Am I limited to the 5v solenoids or is there a way to get 12v output? I found one tutorial on how to achieve this but the link was dead.
I think the garage door opener idea is great, but I am not experienced with any of this so Arduino is where I am able to find resources, things broken down Barney style for me.
