Nano board with Winchiphead - chip
board: Servo Control Board with Winchiphead chip
Operating system on the laptop: Debian 9 and Linux Mint (latest version)
arduino: arduino 1.8.8 - linux64
The problem:
The board is not recognized by the linuxsystem.
upload to board does not work
error information:
avrdude: stk500: programmer is not responding
Must be installed for this chip still a driver the linux systems have not installed normally? Or what is the problem?
The problem:
error information:
Try selecting: Tools
Processor: Atmega328p (Old Bootloader)
Port: /dev/ttyUSB0
It looks like it has succeeded.
Could upload. :slight_smile: :slight_smile: :slight_smile: Did it as you wrote.
Thank you so much for your help!
Another question. Why is not the board in the linux directory?
This is what I see when plugging in a Clone with a CH340 type chip.
$ lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter ************************************
Bus 001 Device 003: ID 1a40:0201 Terminus Technology Inc. FE 2.1 7-port Hub
Bus 001 Device 002: ID 04f2:0833 Chicony Electronics Co., Ltd
Bus 001 Device 004: ID 046d:c077 Logitech, Inc. M105 Optical Mouse
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
$ Dmesg
[10947.697943] usb 1-8.5: new full-speed USB device number 6 using xhci_hcd
[10947.941875] usb 1-8.5: New USB device found, idVendor=1a86, idProduct=7523
[10947.941878] usb 1-8.5: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[10947.941880] usb 1-8.5: Product: USB2.0-Serial
[10949.498267] usbcore: registered new interface driver usbserial_generic
[10949.498277] usbserial: USB Serial support registered for generic
[10949.499602] usbcore: registered new interface driver ch341
[10949.499614] usbserial: USB Serial support registered for ch341-uart
[10949.499626] ch341 1-8.5:1.0: ch341-uart converter detected
[10949.521273] usb 1-8.5: ch341-uart converter now attached to ttyUSB0
Looks a little different for me, of course, but it works. :slight_smile:
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the upload fails you’ll see a button on the right side of the orange bar “Copy error messages”. Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the forum toolbar).
Please don’t cross post.
Duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes writing a detailed answer on this thread, without knowing that someone else already did the same in the other thread.
In the future, take some time to pick the forum section that best suits the topic of your question and then only post once to that forum section. This is basic forum etiquette, as explained in the sticky “How to use this forum - please read.” post you will find at the top of every forum section. It contains a lot of other useful information. Please read it.
Threads merged.
@ kprims
You helped me a lot, really. :slight_smile: :slight_smile: :slight_smile:
It works!!! I just walked with my quadruped through the apartment.
Thanks again. Thanks also to the other users who wanted to help me.
Exactly that was the problem with Debian 9
1.)
Wrong processor was set (ATmega 328P) it must be set to 'ATmega 328P Old Bootloader'.
2.)
Wrong Port ttyS0 - that's the only one offered when you get ATmega238P. Only when I had set the ATmega238P Old Bootloader I could click on the right tools/port/port ttyUSB0.
@ pert
Thanks for your help and message.
I wanted to delete the second as well. But it did not work. Why?
Sorry ! :wink:
Thanks again for the great help.
My quadruped robot is working great now. :slight_smile:
https://www.facebook.com/100009050279670/videos/pcb.2146474688997519/2146482442330077/?type=3&theater
Everyone here says, "that is cool!". Thanks for sharing.
I’m glad to see you got it working SamCha!
