I am trying to speed up the boot time after deep-sleep, and activating logs at the debug level, I get the output below.
I don't understand what it means, except that it looks like the first 279ms are spent to manage the RTC clock calibration.
Am I correct?
Do you see any way to fasten this?
I am using the ESP-IDF to develop the app and configure the hardware.
Many thanks!
--- esp-idf-monitor 1.5.0 on /dev/cu.usbmodem101 115200
--- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H
I (0) cpu_start: App cpu up.
V CACHE_ERR: illegal error intr clr & ena mask is: 0x3f
i (94) clk: waiting fVo r C3A2CkH Eo_sEcRiRl:l actoorre t1o asctcaersts uepr[o0rm
ntr clr & ena mask is: 0x1f
D (278) clk: RTC_SLOW_CLK calibration value: 15999002
V CACHE_ERR: core 0 access error intr clr & ena mask is: 0x1f
I (279) cpu_start: Pro cpu start user code
I (279) cpu_start: cpu freq: 160000000 Hz
I (279) cpu_start: Application information:
I (280) cpu_start: Project name: app
I (280) cpu_start: App version: a76345a-dirty
I (280) cpu_start: Compile time: Oct 6 2024 09:34:48
I (280) cpu_start: ELF file SHA256: b45dfbf0e3d5df62...
I (281) cpu_start: ESP-IDF: v5.1.4-dirty
I (281) cpu_start: Min chip rev: v0.0
I (281) cpu_start: Max chip rev: v0.99
I (281) cpu_start: Chip rev: v0.2
V (281) memory_layout: reserved range is 0x3c03ed48 - 0x3c03ed78
D (282) memory_layout: Checking 7 reserved memory ranges:
D (282) memory_layout: Reserved memory range 0x3c000000 - 0x3e000000
D (282) memory_layout: Reserved memory range 0x3fc84000 - 0x3fc95a00
D (283) memory_layout: Reserved memory range 0x3fc95a
