I was able to use the HID libraries with the following libraries:
#include "USBHIDMouse.h"
#include "USBHIDKeyboard.h"
I believe you have to install the USB library on Arduino IDE to make it work but I'm not sure.
When I wrote this post I was trying to write a code for my Nano ESP32 that would make it so I could use it like a controller. I'll leave the code that was working for me below (some of it is commented because I was just testing it then and we ended up using bluetooth for it):
#include <Arduino.h>
#include "USB.h"
#define XBUTTONKEY 'e'
#define YBUTTONKEY MOUSE_LEFT
#define ABUTTONKEY ' '
#define BBUTTONKEY MOUSE_RIGHT
#define ESCAPEKEY KEY_ESC
#define L3KEY ' '
#define R3KEY ' '
USBHIDMouse Mouse;
USBHIDKeyboard Keyboard;
// set pin numbers for switch, joystick axes, and LED:
//const int switchPin = 2; // switch to turn on and off mouse control
//const int mouseButton = 3; // input pin for the mouse pushButton
const int xAxis1 = A0; // joystick1 X axis
const int yAxis1 = A1; // joystick1 Y axis
const int xAxis2 = A4; // joystick2 X axis
const int yAxis2 = A5; // joystick2 Y axis
const int joystickL3 = D2;
const int upButton = D4;
const int leftButton = D5;
const int downButton = D6;
const int rightButton = D7;
const int escapeButton = D3;
const int xButton = D8;
const int yButton = D9;
const int aButton = D10;
const int bButton = D11;
const int joystickR3 = D13;
// parameters for reading the joystick:
int range = 12; // output range of X or Y movement
int responseDelay = 5; // response delay of the mouse, in ms
int threshold = range/6; // resting threshold
int center = range/2; // resting position value
bool mouseIsActive = true; // whether or not to control the mouse
int lastSwitchState = LOW; // previous switch state
//Configure pins as an input and enable the internal pull-up resistor,
pinMode(joystickL3, INPUT_PULLUP);
pinMode(xButton, INPUT_PULLUP);
pinMode(yButton, INPUT_PULLUP);
pinMode(aButton, INPUT_PULLUP);
pinMode(bButton, INPUT_PULLUP);
pinMode(upButton, INPUT_PULLUP);
pinMode(leftButton, INPUT_PULLUP);
pinMode(downButton, INPUT_PULLUP);
pinMode(rightButton, INPUT_PULLUP);
pinMode(joystickR3, INPUT_PULLUP);
pinMode(escapeButton, INPUT_PULLUP);
//Start Mouse and Keyboard control as well as USB
Mouse.begin();
Keyboard.begin();
USB.begin();
// joystick control
bool xButRead = !digitalRead(xButton);
bool yButRead = !digitalRead(yButton);
bool aButRead = !digitalRead(aButton);
bool bButRead = !digitalRead(bButton);
bool joyL3Read = !digitalRead(joystickL3);
bool upButRead = !digitalRead(upButton);
bool leftButRead = !digitalRead(leftButton);
bool downButRead = !digitalRead(downButton);
bool rightButRead = !digitalRead(rightButton);
bool joyR3Read = !digitalRead(joystickR3);
bool escButRead = !digitalRead(escapeButton);
// read and scale the two axes:
int xReading1 = readAxis(xAxis1);
int yReading1 = readAxis(yAxis1);
int xReading2 = readAxis(xAxis2);
int yReading2 = readAxis(yAxis2);
// if the mouse control state is active, move the mouse:
if (mouseIsActive) {
Mouse.move(yReading2, -xReading2, 0);
if(xReading1 == 0){
Keyboard.release('s');
Keyboard.release('w');
} else if(xReading1 > 0){
Keyboard.press('w');
} else{
Keyboard.press('s');
if(yReading1 == 0){
Keyboard.release('d');
Keyboard.release('a');
} else if(yReading1 > 0){
Keyboard.press('d');
} else{
Keyboard.press('a');
// button control
//If corresponding button is pressed
if (xButRead) {
//Press 'x',
Keyboard.press(XBUTTONKEY);
} else{
Keyboard.release(XBUTTONKEY);
if (yButRead) {
//Press 'y',
Mouse.press(YBUTTONKEY);
} else{
Mouse.release(YBUTTONKEY);
if (aButRead) {
//Press 'a',
Keyboard.press(ABUTTONKEY);
} else{
Keyboard.release(ABUTTONKEY);
if (bButRead) {
//Press 'b',
Mouse.press(BBUTTONKEY);
} else{
Mouse.release(BBUTTONKEY);
if (joyL3Read){
//Press 'b',
Keyboard.press('b');
} else{
Keyboard.release('b');
//COMPATIBILITY ISSUES WITH THE JOYSTICK
if (upButRead) {
//Press 'w',
} else{
if (leftButRead) {
//Press LEFT_ARROW,
//Serial.println("LEFT was pushed");
} else{
if (downButRead) {
//Press DOWN_ARROW,
//Serial.println("DOWN was pushed");
} else{
if (rightButRead) {
//Press RIGHT_ARROW,
//Serial.println("RIGHT was pushed");
} else{
if (joyR3Read){
Keyboard.press(KEY_RIGHT_ARROW);
} else{
if (escButRead){
//Press ESCAPE,
Keyboard.press(ESCAPEKEY);
} else{
Keyboard.release(ESCAPEKEY);
delay(1);
reads an axis (0 or 1 for x or y) and scales the analog input range to a range
from 0 to <range>
int readAxis(int thisAxis) {
// read the analog input:
int reading = analogRead(thisAxis);
// map the reading from the analog input range to the output range:
reading = map(reading, 0, 4095, 0, range);
// if the output reading is outside from the rest position threshold, use it:
int distance = reading - center;
if (abs(distance) < threshold) {
distance = 0;
// return the distance for this axis:
return distance;
If you have any questions about it feel free to ask about it, I'll try my best to answer them.
