Hello together,
I try to use the Arduino Nano ESP 32 with the Lib TFT_eSPI (latest Version) and the Adafruit TFT 1.8 Zoll with driver ASIC ST 7735S.
After Lib was installed I modified the User_Setup.h and User_Setup_Select.h.
My settings are:
#include <User_Setups/Setup43_ST7735.h>
--> in file User_Setup_Select.h
Next in User_Setup.h
#define ST7735_DRIVER
#define TFT_WIDTH 128
#define TFT_HEIGHT 160
#define ST7735_BLACKTAB
#define TFT_INVERSION_OFF
#define TFT_MOSI 11 // In some display driver board, it might be written as "SDA" and so on.
#define TFT_SCLK 13
#define TFT_CS 9 // Chip select control pin
#define TFT_DC 8 // Data Command control pin
#define TFT_RST 7 // Reset pin (could connect to Arduino RESET pin)
According this pins settings I have connected the TFT display with the Arduino Board.
Other pins like VCC, Gnd and Led are also connected.
I can see no reaction on the TFT. Still it is lighted on and will not show any details when using an example like Colour_Wheel.ino or else.
Does someone has more success on this topic?
Thanks for helping
Best regards Mascho11
Hello @mascho11, the Nano ESP32 has a different handling of sketches with pin numbers. Please read this document for more information. Make sure to:
- choose "Tools" > "Pin Numbering" > "By GPIO number" in the IDE
- use symbols when referring to pin numbers, like this:
#define TFT_MOSI D11
#define TFT_SCLK D13
#define TFT_CS D9
#define TFT_DC D8
#define TFT_RST D7
(obviously double-check if these actually match your connections on the board! )
Let me know if this helps!
Hello Iburelli,
Good day. Thanks for your help and support.
I was aware of this topic with Arduino Pin and GPIO. But I thougt both are supported and I need to choose one of both.
But ok I changed: "Tools" > "Pin Numbering" > "By GPIO number"
And sorted the pins new:
#define TFT_MISO 47 // D12
#define TFT_MOSI 38 // D11 In some display driver board, it might be written as "SDA" and so on.
#define TFT_SCLK 48 // D13
#define TFT_CS 18 // D9Chip select control pin
#define TFT_DC 17 // D8 Data Command control pin
#define TFT_RST 10 // D7 Reset pin (could connect to Arduino RESET pin)
This alone helped not. I changed some settings inslide the configuration. At the end it was this setting I have undone:
old: #include <User_Setups/Setup43_ST7735.h>
new: #include <User_Setup.h>
Default setup
With this and your pin setting now the Dispay is working and the basic scatches are running as expected.
Thank you and best regards
Mascho11
