It is easier to provide help if you post your sketch in a reply (using code tags when you do) rather than attaching it
#include <Arduino_FreeRTOS.h>
#include <semphr.h>
#include <megaAVR_TimerInterrupt.h>
#include <megaAVR_TimerInterrupt.hpp>
#include <megaAVR_ISR_Timer.h>
#include <megaAVR_ISR_Timer.hpp>
#include <SoftwareSerial.h>
// inslude the SPI library:
//#include <SPI.h>
#define SCHEDULING_TIMER_BLDC 20
#define SCHEDULING_TIMER 20 // wait for 16.60ms ~60 Hz
#define KEYPRESSCOUNT 5
#define KEYPRESSCOUNTLOW 0
#define KEYPRESSCOUNTHIGH 5
#define FINEDINE 14
#define ADCHAN 4
#define TOPPWMVALUE 225
#define DUTYVALUE 76
// add the FreeRTOS functions for Semaphores (or Flags).
/// These constants won't change. They're used to give names to the pins used:
const int analogInPin = A0; // Analog input pin that the power supply monitor is attached to
const int analogInPinSO1 = A6; // Analog input pin that the SHx
const int analogInPinSO2 = A5; // Analog input pin that the SHx
const int analogInPinSO3 = A7; //Analog input pin that the SHx
// constants won't change. Used here to set a pin number;
const int ledPin = LED_BUILTIN; // the number of the LED pin
// set pin 10 as the slave select for the digital pot:
const int slaveSelectPin = 10;
//const int ledPin = LED_BUILTIN;// the number of the LED pin
int Leddrive = LOW;
int ledState = LOW;
int PrevledState = HIGH; // DRIVE MOTOR STATUS
int SteerState = LOW;
int PrevSteerState = HIGH; // STEER MOTOR STATUS
int ButtonState = LOW, bitspistate;
unsigned int simplecnt = 0;
unsigned int humblecount = 0;
unsigned int ADcount = 0;
int sensorValue = 0; // value read from the pot
int outputValue = 0; // value output to the PWM (analog out)
int sensorValue1[8][15];
int ADCCHEK;
unsigned int loccount = 0;
unsigned int count = 0, freecount;
unsigned int MotorDelay = 0;
static unsigned int bldcphasecount = 0;
static unsigned int rpmmotor = 400, rpmmotor1 = 400; // 30 deg electrical Angular equivalent RPM count
// digital pin 2 has a pushbutton attached to it. Give it a name:
uint8_t pushButton = 2;
char Rxport;
unsigned char itimer1, itimer2, adclow, adchigh;
int buttonState[6];
const unsigned int DrvMode[16] = { 0x0000, 0x8800, 0x9000, 0x9800, 0xa000, 0x2b78, 0x3378, 0x3b36, 0xc000, 0xc820, 0x503f, 0xda0a, 0x6058, 0x0000, 0x0000, 0x0000 };
enum BUTTON_T
PRESS,
POSTPRESS,
PRESSLOOK,
POSTPRESSLOOK
enum MOTORSPEED_T
GEAR0,
GEAR1,
GEAR2,
GEAR3
enum BLDCMOTOR_T
ACCEL0,
ACCEL1,
ACCEL2,
ACCEL3,
ACCEL4,
ACCEL5,
ACCEL6,
ACCEL7,
ACCEL8,
ACCEL9,
ACCEL10,
ACCEL11,
ACCEL12,
DECEL,
BEMF1,
BEMF2,
STOP,
ALIGN
enum MOTORSPEEDRAMP_T
ASCEND,
DESCEND,
SLOW
MOTORSPEEDRAMP_T RampCntrl = ASCEND;
MOTORSPEED_T motorspeed_state = GEAR0;
BUTTON_T stateofbutton = PRESSLOOK;
BLDCMOTOR_T bldcstate = STOP;
unsigned int Period, Period0, Period1, Period2;
unsigned int Period3 = 0;
unsigned short int k = 0;
byte Phase[] = { B01100000, B01010000, B01110000, B01000000, B00000010, B11111101 }; //Lookup Table pb1 - least, HL format, only pb1 hi or, low and func, d4/d5 direct portd writes...
//long unsigned int change1, change2, change0 ;
// Declare a mutex Semaphore Handle which we will use to manage the Serial Port.
// It will be used to ensure only only one Task is accessing this resource at any time.
SemaphoreHandle_t xSerialSemaphore;
// define two Tasks for DigitalRead & AnalogRead
void TaskDigitalRead(void *pvParameters);
void TaskHumbleRead(void *pvParameters);
void setup(void);
void Func_accel0( void );
void Func_accel2( void );
void Func_accel4( void );
void Func_accel6( void );
void Func_accel8( void );
void Func_accel10( void );
void Func_accel12( void );
void Func_accel_comm( void );
typedef void (*fptr)(void);
const fptr AccelFuncptr[13] = {Func_accel0,Func_accel_comm,Func_accel2,Func_accel_comm,Func_accel4,Func_accel_comm,Func_accel6,Func_accel_comm,Func_accel8,Func_accel_comm,Func_accel10,Func_accel_comm,Func_accel12} ;
// the setup function runs once when you press reset or power the board
PORTA.DIR = 0x83; // PA7 config for CLKOUT chks of CLK_PER value - remove later after DEBUG
PORTA.OUT = 0x0;
PORTB.DIR = 0x03;
PORTB.OUT = 0x0;
PORTC.DIR = 0x50;
PORTC.OUT = 0x0;
PORTD.DIR = 0x07;
PORTD.OUT = 0x0;
// port E all are i/ps so no initial value needed
PORTE.DIR = 0x05;
PORTE.OUT = 0x0;
PORTF.DIR = 0x10;
PORTF.OUT = 0x0;
// initialize serial communication at 9600 bits per second:
// deafult drive code
//analogReference(DEFAULT);
while (!Serial)
; // wait for serial port to connect. Needed for native USB, on LEONARDO, MICRO, YUN, and other 32u4 based boards.
// Semaphores are useful to stop a Task proceeding, where it should be paused to wait,
// because it is sharing a resource, such as the Serial port.
// Semaphores should only be used whilst the scheduler is running, but we can set it up here.
if (xSerialSemaphore == NULL) // Check to confirm that the Serial Semaphore has not already been created.
xSerialSemaphore = xSemaphoreCreateMutex(); // Create a mutex semaphore we will use to manage the Serial Port
if ((xSerialSemaphore) != NULL)
xSemaphoreGive((xSerialSemaphore));
// Make the Serial Port available for use, by "Giving" the Semaphore.
/* Disable interrupts */
cli(); //stop interrupts
// Timer Init for TB0/1/2 For FRQPW modes
// Timers B & A
//TCA0.SINGLE.CTRLB = 0x01 ; //default is single PWM mode by arduino IDE
//TCA0.SINGLE.CTRLA = 0x09 ; //default arduino IDE provides divide by 64
//TCA0.SINGLE.CMP0 = 0x0064 ;
//TCB0.CTRLB = 0x05 ;
//TCB0.EVCTRL = 0x01 ;
// Timers 1
TCB1.CTRLB = 0x05;
TCB1.EVCTRL = 0x01;
//TCB1.INTCTRL = 0x01 ;
TCB1.CTRLA = 0x05;
// Timers 2
TCB2.CTRLB = 0x05;
TCB2.EVCTRL = 0x01;
//TCB2.INTCTRL = 0x01 ;
TCB2.CTRLA = 0x05;
// EVSYS Drivers
//EVSYS.CHANNEL0 = 0x42 ;
EVSYS.CHANNEL4 = 0x4D;
EVSYS.CHANNEL5 = 0x43;
// EVSYS.CHANNEL1 = 0x84 ; // TCA0 CMP0 events connected to channel 1
//EVSYS.USERTCB0 = 0x01 ; // TCB0 to CH0
EVSYS.USERTCB1 = 0x05; // TCB1 to CH4
EVSYS.USERTCB2 = 0x06; // TCB2 to CH5
// set the digital pin as output:
// PWMA,PWMB,PWMC hold on zero
// Engate cmd ZERO
//delay(10);
for (unsigned int i = 0; i <= 14; i++)
sensorValue1[7][i] = 620;
Serial.println("\n\t ADC FILL DONE");
// enable PWM
// 1-PWM drive
//TIMER TCB0 SET UP
//timer TCB0 -- interrupt @32uS
TCBROUTEA = 0x01; // TCB0 o/p routed to PF4/D6 - Arduino port
TCB0.CTRLA = 0x04; // TCA0 CLK Chosen, but TCB disabled still
TCB0.CTRLB = 0x07; // 8 bit PWM mode chosen for TCB0 timer
TCB0.CCMPL = DUTYVALUE;
TCB0.CCMPH = TOPPWMVALUE;
TCB0.INTCTRL = 0x01; // interrupt enabled in 8bit PWM mode
//TCB0.CTRLA = 0x05 ; // TCB0 enabled
//the following port pins are configured for rising edge interrupt if configured as I/Ps
PORTF.PIN3CTRL = 0x02; // A5/SCL ARDUINO PORT
PORTE.PIN3CTRL = 0x02; // D8 ARDUINO PORT
PORTA.PIN1CTRL = 0x02; // D7 ARDUINO PORT
sei(); //allow interrupts
// Now set up two Tasks to run independently.
xTaskCreate(
TaskDigitalRead, (const portCHAR *)"DigitalRead" // A name just for humans
128 // This stack size can be checked & adjusted by reading the Stack Highwater
NULL, 3 // Priority, with 3 (configMAX_PRIORITIES - 1) being the highest, and 0 being the lowest.
NULL);
xTaskCreate(
TaskHumbleRead, (const portCHAR *)"HumbleRead" // A name just for humans
NULL, 1 // Priority, with 3 (configMAX_PRIORITIES - 1) being the highest, and 0 being the lowest.
NULL);
// Now the Task scheduler, which takes over control of scheduling individual Tasks, is automatically started.
ISR(ADC_vect)
adclow = ADCL;
adchigh = (ADCH & 0x03);
sensorValue1[(ADMUX & 0x07)][count] = (unsigned int)((((unsigned int)adchigh) << 8) | ((unsigned int)adclow));
//freecount = freecount + 1 ;
count = count + 1;
ISR(TIMER1_OVF_vect)
Period3 += 1;
/*******ISRs**
ISR(PCINT0_vect)
TCCR1B = 0x18 ; //0HZTCCR1B &= ~(1<< CS10);//Stoping timer
PIND|=B00010000;//PIN B to One
Period=ICR1;
OCR1A=(Period>>1);
k=0;
TCNT1=0;
TCCR1B = 0x19 ; //16MhzTCCR1B &= (1<< CS10);//Starting timer
ISR(PCINT1_vect)
TCCR1B = 0x18 ; //0HZ Stoping timer
PIND&=B11110111;//PIN A to Zero
Period=ICR1;
OCR1A=(Period>>1);
k=1;
TCNT1=0;
TCCR1B = 0x19 ; //16Mhz//Starting timer
ISR(PCINT2_vect)
TCCR1B = 0x18 ; //0HZ//Stoping timer
PIND&=B11011111;//Pin C to Zero
Period=ICR1;
OCR1A=(Period>>1);
k=2;
TCNT1=0;
ISR(TIMER1_COMPB_vect)
PIND|=Phase[k];//Commute
ISR(PCINT0_vect)
if((PINB & 0x01))
TCCR1B = 0;//Stoping timer
Period0=TCNT1;
//OCR1A=(Period>>1);
//k=0;
TCNT1=0;
TCCR1B = 4;//Starting timer
//change0 += 1 ;
//pb0 port
ISR(PCINT1_vect)
if((PINC & 0x20))
Period1=TCNT1;
//k=0;
TCNT1=0;
//change1 += 1 ;
//pc5
ISR(PCINT2_vect)
if((PIND & 0x80))
Period2=TCNT1;
//k=0;
TCNT1=0;
TCCR1B = 4 ;//Starting timer
//change2 += 1 ;
//pd7
ISR(TIMER2_OVF_vect)
//timer1 interrupt
switch (bldcstate)
case STOP:
//digitalWrite(3, LOW);// ports must be zero D3 XCHG TO B1
//digitalWrite(4, LOW);
//digitalWrite(5, LOW);
//PORTB = (B11111101 & PORTB);
PORTD = B01000000; //digitalWrite(6, HIGH); // ENGATE
bldcphasecount = 0;
bldcstate = ALIGN;
case ALIGN:
if (bldcphasecount == 0)
PORTB = (B00000010 | PORTB); //digitalWrite(3, HIGH); B1 XCHG
PORTD = B01110000;
//digitalWrite(4, HIGH);
//digitalWrite(5, HIGH);
bldcphasecount = bldcphasecount + 1;
else if (bldcphasecount < 32000)
// 1-PWM drive 99% DUTY for entering accel
bldcphasecount = 0;
bldcstate = ACCEL0;
case ACCEL0:
//*AccelFuncptr[bldcphasecount] ;
PORTB = (B11111101 & PORTB); //digitalWrite(3, LOW);
//PORTD = B01110000 ;
else if (bldcphasecount < rpmmotor)
bldcstate = ACCEL1;
bldcphasecount = 0;
case ACCEL1:
// odd states commute cmds
//freecount = 0 ;
bldcstate = ACCEL2;
bldcphasecount = 0;
case ACCEL2:
PORTD = B01010000; //digitalWrite(5, LOW);
bldcstate = ACCEL3;
bldcphasecount = 0;
case ACCEL3:
//freecount = 0 ;
bldcstate = ACCEL4;
bldcphasecount = 0;
case ACCEL4:
PORTB = (B00000010 | PORTB); //PORTD = B01011000 ;//digitalWrite(3, HIGH);
bldcstate = ACCEL5;
bldcphasecount = 0;
case ACCEL5:
//freecount = 0 ;
bldcstate = ACCEL6;
bldcphasecount = 0;
case ACCEL6:
PORTD = B01000000; //digitalWrite(4, LOW);
bldcstate = ACCEL7;
bldcphasecount = 0;
case ACCEL7:
//freecount = 0 ;
bldcstate = ACCEL8;
bldcphasecount = 0;
case ACCEL8:
PORTD = B01100000; //digitalWrite(5, HIGH);
bldcstate = ACCEL9;
bldcphasecount = 0;
case ACCEL9:
//freecount = 0 ;
bldcstate = ACCEL10;
bldcphasecount = 0;
case ACCEL10:
PORTB = (B11111101 & PORTB); //PORTD = B01100000; //digitalWrite(3, LOW);
bldcstate = ACCEL11;
bldcphasecount = 0;
case ACCEL11:
//freecount = 0 ;
bldcstate = ACCEL12;
bldcphasecount = 0;
case ACCEL12:
PORTD = B01110000; //digitalWrite(4, HIGH);
//or BEMF1 if RPM exceeds BEMFTHR
bldcstate = ACCEL1;
rpmmotor = rpmmotor1;
bldcphasecount = 0;
case DECEL:
case BEMF1:
default:
bldcstate = STOP;
bldcphasecount = 0;
// Empty. Things are done in Tasks.
// /*---------------------- Tasks ---------------------*/
void TaskDigitalRead(void *pvParameters __attribute__((unused))) // This is a Task.
//digitalWrite(ledPin, LOW);
//freecount = 0 ;
//start motor PWM cmd only
TCCR2B = 0x01; //starts clk io to timer2 //16Mhz
//change1 = 0;
//change2 = 0;
//change0 = 0;
for (;;) // A Task shall never return or exit.
// read the input pin:
//digitalWrite(ledPin, Leddrive);
// Leddrive = !Leddrive ;
// Motor control portion
// them monitor logic - exit - BATTERY VALUE 670 decimal is good for stop motor control or 660.
// based on RC o/p for motor logic/direction change for sterr+drive, set direction for motor.example only below .all info from Serial port Rx Task
// first to stop PWM:
if (PrevledState != ledState)
if (ledState == LOW)
// print the results to the Serial Monitor:
digitalWrite(7, HIGH);
if (MotorDelay < 8)
MotorDelay = MotorDelay + 1 ;
MotorDelay = 0 ;
//delay(100);
digitalWrite(8, LOW);//6 shud opeartw
PrevledState = ledState ;
if (ledState == LOW) {
//analogWrite(6, outputValue);
//analogWrite(5, outputValue);
// See if we can obtain or "Take" the Serial Semaphore.
// If the semaphore is not available, wait 5 ticks of the Scheduler to see if it becomes free.
if ( xSemaphoreTake( xSerialSemaphore, ( TickType_t ) 1 ) == pdTRUE )
// We were able to obtain or "Take" the semaphore and can now access the shared resource.
// We want to have the Serial Port for us alone, as it takes some time to print,
// so we don't want it getting stolen during the middle of a conversion.
// print out the state of the button:
Serial.println("\n\t MotorControl = Forward");
Serial.println("\n\t MotorControl = Reverse");
xSemaphoreGive( xSerialSemaphore ); // Now free or "Give" the Serial Port for others.
digitalWrite(8, HIGH);
if (MotorDelay < 8)
MotorDelay = 0 ;
//delay(100);
digitalWrite(7, LOW);// 5 shud operaTE
//Battery Monitor portion
if (count < 8)
ADMUX |= 0x07; //0x47 ; // repeat in isr cpde for A7
ADCSRA = 0xDF; //SOC BIT 6
//sensorValue1[count] = analogRead(analogInPin);
count = 0;
sensorValue = 0;
while (count < 8)
sensorValue += sensorValue1[7][count];
count = count + 1;
sensorValue = (sensorValue >> 3);
count = 0;
if (sensorValue >= 500)
// map it to the range of the analog out, ready for supply voltage based Pwm Control, extend 4 or 5 sample averaging here.
outputValue = map(sensorValue, 600, 750, 255, 0);
// 490 coreesponds to 4.5 volts, aref=3.3volts, 22k/12k
//outputValue = (255 - outputValue) ;
//outputValue = (outputValue >> 1) ;
// inkl logic for battery cut off...or warning or stop control of motor
if (outputValue > 255)
outputValue = 255;
else if (outputValue < 0)
outputValue = 0;
if (outputValue != 0)
outputValue = (outputValue >> motorspeed_state);
if (simplecnt <= 57)
simplecnt = simplecnt + 1;
simplecnt = 0;
if (xSemaphoreTake(xSerialSemaphore, (TickType_t)1) == pdTRUE)
// print out the value you read:
//Serial.println("\n\t Sensor Value");
Serial.println(sensorValue);
// Serial.println("\n\t PWM Value");
//Serial.println(outputValue);
xSemaphoreGive(xSerialSemaphore); // Now free or "Give" the Serial Port for others.
outputValue = 0;
if (sensorValue < 580)
if (simplecnt <= 9)
simplecnt = 0;
Serial.print("\n\t battlow");
// Serial.print(" sensor = ");
Serial.print(sensorValue);
// Serial.println("\n\t\t ");
//serial port checks...
if (Serial.available())
Rxport = Serial.read();
if (Rxport == '0')
rpmmotor1 = 350;
else if (Rxport == '1')
motorspeed_state = GEAR1;
rpmmotor1 = 300;
else if (Rxport == '2')
motorspeed_state = GEAR2;
rpmmotor1 = 250;
else if (Rxport == '3')
motorspeed_state = GEAR3;
rpmmotor1 = 200;
else if (Rxport == '+')
//OCR1A += 5 ;
OCR2B += 5; // duty cycle
else if (Rxport == '-')
//OCR1A -= 5 ;
OCR2B -= 5; // duty cycle
Serial.println("\n\t RXPORT");
Serial.println(Rxport);
//Serial.println(OCR1A);
Serial.println(OCR2B);
//Rxport1 = Rxport;
// xSemaphoreGive( xSerialSemaphore ); // Now free or "Give" the Serial Port for others.
/**if ( xSemaphoreTake( xSerialSemaphore, ( TickType_t ) 1 ) == pdTRUE )
{ // We were able to obtain or "Take" the semaphore and can now access the shared resource.
//Serial.println("\n\t PushButton = LOW");
//ledState = !ledState ;
Serial.println("\n\t Pressed");//Serial.println(buttonState);
//stateofbutton = POSTPRESSLOOK ;
vTaskDelay(SCHEDULING_TIMER / portTICK_PERIOD_MS); //pdMS_TO_TICKS()
//vTaskDelay( pdMS_TO_TICKS(16.6) );
void TaskHumbleRead(void *pvParameters __attribute__((unused))) // This is a Task.
//push button read portion
switch (stateofbutton)
case PRESSLOOK:
if (loccount <= KEYPRESSCOUNT)
buttonState[loccount] = digitalRead(pushButton);
loccount = loccount + 1;
stateofbutton = PRESS;
case PRESS:
ButtonState = LOW;
loccount = KEYPRESSCOUNTLOW;
while (loccount <= KEYPRESSCOUNTHIGH)
if (!buttonState[loccount])
//Serial.println("\n\t PushButton = HIGH");
//xSemaphoreGive( xSerialSemaphore ); // Now free or "Give" the Serial Port for others.
loccount = 0;
ButtonState = HIGH;
if (ButtonState)
ButtonState = LOW;
ledState = !ledState;
stateofbutton = POSTPRESSLOOK;
Serial.println("\n\t PushButton = Pressed"); //Serial.println(buttonState);
loccount = 0;
case POSTPRESSLOOK:
stateofbutton = POSTPRESS;
case POSTPRESS:
ButtonState = LOW;
if (buttonState[loccount])
loccount = 0;
ButtonState = HIGH;
if (ButtonState)
ButtonState = LOW;
// stateofbutton = LOOK ;
loccount = 0;
if (humblecount <= 6)
humblecount = humblecount + 1;
switch (RampCntrl)
case ASCEND:
if (rpmmotor1 >= 25)
rpmmotor1 -= 5;
//RampCntrl = DESCEND ;
//rpmmotor1 = rpmmotor1 ;//rpmmotor1 += 5 ;
RampCntrl = SLOW;
case DESCEND:
if (rpmmotor1 <= 400)
rpmmotor1 += 5;
RampCntrl = ASCEND;
rpmmotor1 -= 5;
case SLOW:
if (rpmmotor1 > FINEDINE)
rpmmotor1 -= 1;
PCICR = 0x07; // pc interrupts enabled....
if (k == 0)
Serial.println("\n\t PCINT 0 :");
Serial.println(Period0);
k += 1;
else if (k == 1)
Serial.println("\n\t PCINT 1 :");
Serial.println(Period1);
k += 1;
else if (k == 2)
Serial.println("\n\t PCINT 2 :");
Serial.println(Period2);
k += 1;
else if (k == 3)
Serial.println("\n\t TIMER1_OVFF :");
k = 0;
if (ADcount > 12)
ADcount = 0;
//rpmmotor1 += 5 ;
/**if(OCR1A >= 0x000B)
OCR1A -= 0x000A ; // duty cycle value
else if (OCR1A >= 0x0180)
OCR1A += 0x000A ; // duty cycle value
humblecount = 0;
// void BushButtonRead() ;
vTaskDelay(SCHEDULING_TIMER_BLDC / portTICK_PERIOD_MS);
// vTaskDelay( 1000 / portTICK_PERIOD_MS );
//vTaskDelay( 10 );
