Yes I am positive about the OLED address and no the headers are not soldered on to the Nano every. I did solder an OLED onto the every and that didn't work either I am definitely getting continuity on the pins although they are not soldered. Once I run the first sketch the orange LED blinks and it's uploaded after that the orange light does not blink anymore if I try to reupload a sketch .I do however have a regular Nano and the OLED runs perfectly with the simple sketch the reason why I got the every is because I do not want headers on the Nano is there a version of the Nano that does not have headers.
Yeah sorry about the code format that was out of frustration I guess. The back light does not turn on at all I do however have a nano the code uploaded in a few seconds and the OLED said hello I'm pretty sure the issue is with all three Nano every boards that I have
A simple code works perfectly with the regular Nano I just need a nano with no header. Do I have to sit here with the solder sucker and remove the header myself?
Yes, i went w the 5v first. I first used a 1.3 in screen. Colplete garbage. No address. I'm still wondering where the orange led went after the first script.
The orange LED is the onboard LED, it will only blink if you have code driving it.
I have no problem with your sketch on a Nano Every with an OLED display, using either 5V or 3.3V as the power supply. Wiring is identical to the Nano (I unplugged one and plugged the other in without changing the OLED wiring).
