Nano every upload problem
I can't upload the code to nano every board.
The port is not visible on the IDE, although I am using a data cable.
I tested with UNO, it works.
Have you downloaded drivers? Check if they installed correctly
Hi, @attilamolnardk and @demontd
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
This will help with advice on how to present your code and problems.
What version IDE and what OS are you running.
A lot of Nano clones are loaded with the old bootloader, but that should not cause your problem.
Can you look on the Nano PCB and see if you can identify the USB IC, it could be a CH340.
If so this may help;
https://learn.sparkfun.com/tutorials/how-to-install-ch340-drivers/all
Or google arduino CH340 driver.
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
EDIT
PS. Sorry you are using an Every..my mistake.
Bear with me, looking into my crystal ball…
Please check the getting started section of the Nano Every. If you are still getting issues with the board do not hesitate to get in touch with Arduino Support team.
Getting started: https://docs.arduino.cc/hardware/nano-every
Support: https://www.arduino.cc/en/contact-us/
Hi !
Might be a firmware probblem. I had something similar. Maybe solution described here might help:
https://forum.arduino.cc/t/arduino-nano-every-upload-of-sketch-suddenly-not-possible-anymore/945089/20
