Nano Every USB + 12V VIN burn out during sketch upload
I had a nano power regulator blow out when I tried uploading a sketch while I was supplying 12V to the VIN pin and had the USB plugged in at the same time. I realized I had two normally open reed sensors wired to ports D18 and D19 (respectively the SDA and SDL ports) as pull-up resistor inputs. Before I plugged in 12V to VIN and just was powering my set-up via USB things worked fine. That is to say my sensors did their job and a light wired through D2 went on to indicated when either sensor was active. Then when I tested my set-up with 12V to the VIN alone I noticed my lights were going on when the sensors should have been open. I plugged in the USB and tried uploading a correction to the sketch, the upload process wasn't working and before I could do anything I started smelling hot electronics. After some time and investigation I realized I didn't have my sensors wired to proper input pins. I rewired my circuit with a new NANO Every and everything works fine under 12V power.
Here's the thing I'm scared to upload a sketch or even plugin the USB while 12V power is being supplied via VIN. Should I be? Did I only have a problem because I uploaded a sketch while I had the SDA and SDL ports coded as pull-up resistors? Is it best practice to just cut-off any unregulated power to the board when uploading a sketch in general?
-RG
Why are you using 12V? Get a 5V supply.
I use these in a lot of projects when 12V is not used elsewhere in the project.
I'm using 12v because I'm also controlling a stepper motor and using the available power from the supply and don't want more wires than necessary. Also, the NANO doesn't have 5V plug-in for that wall wart, are you suggesting plugging it into the +5V pin? I need that to power another board for RS485/MODBUS communication, without having to split up more wiring.
-RG
The Nano Every has a nice little switching regulator module that SHOULD do a lot better than previous efforts.
But it seems to have some failure modes that aren’t well understood yet :frowning:
It just seems to me that this is the key:
ryangrg:
Maybe the switches weren't open and were shorting something out on the board. "Best practice" is to double check all wiring before applying any power.
