Nano freezes when trying to read Temperature/Humidity DHT11
I'm using code for a digital clock written by someone else (freely shared by the author). I had another issue with this clock here [Arduino Nano clock project, WS2812B RGB LEDs] which has been resolved.
Hardware: Arduino Nano, Bluetooth Module, Temp and Humidity sensor, Real Time Clock Module.
I have another issue:
Any time I try to read the temperature or humidity the nano freezes. I'm using Leon's code unmolested. I am using serial monitor for some troubleshooting. If you check the void displayTemperature() loop I am getting up to float tmp = dht.readTemperature(); but not Temperature successfully read As soon as the nano tries to read the pin it freezes. If I disconnect the DHT 11 from pin 12, I do get to the Failed to read from DHT sensor! message. I've tried other pins with no luck. Trying to read humidity also results in the nano freezing.
I have tried the generic sketch for the DHT11 and I can read the temp/humidity, so it's working and is wired correctly. I've replaced leons code in the void displayTemperature() loop with the generic test code and the nano freezes.
Clock, scoreboard, counter works fine (now).
Thank you for any assistance.
Sorry, Here is the sketch:
   MIT License
   Copyright (c) 2018 Leon van den Beukel
   Permission is hereby granted, free of charge, to any person obtaining a copy
   of this software and associated documentation files (the "Software"), to deal
   in the Software without restriction, including without limitation the rights
   to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
   copies of the Software, and to permit persons to whom the Software is
   furnished to do so, subject to the following conditions:
   The above copyright notice and this permission notice shall be included in all
   copies or substantial portions of the Software.
   THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
   IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
   FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
   AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
   LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
   OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
   SOFTWARE.
   Source:
   https://github.com/leonvandenbeukel/3D-7-Segment-Digital-Clock
   External libraries you need:
   Adafruit Sensor Library:   https://github.com/adafruit/Adafruit_Sensor
   Adafruit RTCLib:           https://github.com/adafruit/RTClib
   FastLED:                   https://github.com/FastLED/FastLED
   Timer Library:             https://github.com/JChristensen/Timer
#include <DHT.h>
#include <DHT_U.h>
#include <FastLED.h>
#include <Wire.h>
#include "RTClib.h"
#include <SoftwareSerial.h>
#include "Timer.h"
#define DHTPIN 12
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
#define NUM_LED_PRO_SEG 3
#define NUM_LEDS (NUM_LED_PRO_SEG * 7 * 4 + 2)
#define DATA_PIN 6
CRGB LEDs[NUM_LEDS];
SoftwareSerial BTserial(8, 9);
RTC_DS3231 rtc;
Timer t1;
Timer t2;
Timer t3;
String btBuffer;
CRGB colorCRGB = CRGB::Red;           // Change this if you want another default color, for example CRGB::Blue
CHSV colorCHSV = CHSV(95, 255, 255);  // Green
//CRGB colorOFF  = CRGB(20, 20, 20);    // Color of the segments that are 'disabled'. You can also set it to CRGB::Black
CRGB colorOFF = CRGB::Black;  // Color of the segments that are 'disabled'. You can also set it to CRGB::Black
volatile byte colorMODE = 1;  // 0=CRGB, 1=CHSV, 2=Constant Color Changing pattern
volatile byte mode = 0;       // 0=Clock, 1=Temperature, 2=Humidity, 3=Scoreboard, 4=Time counter
volatile byte scoreLeft = 0;
volatile byte scoreRight = 0;
volatile long timerValue = 0;
volatile int timerRunning = 0;
#define blinkDots 0          // Set this to 1 if you want the dots to blink in clock mode, set it to value 0 to disable
#define hourFormat 12        // Set this to 12 or to 24 hour format
#define temperatureMode 'C'  // Set this to 'C' for Celcius or 'F' for Fahrenheit
#define Seg4 (21 * NUM_LED_PRO_SEG + 2)
#define Seg3 (14 * NUM_LED_PRO_SEG + 2)
#define Seg2 (7 * NUM_LED_PRO_SEG)
  // Initialize LED strip
  FastLED.delay(3000);
  // Check if you're LED strip is a RGB or GRB version (third parameter)
  FastLED.addLeds<WS2812B, DATA_PIN, GRB>(LEDs, NUM_LEDS);
  while (!Serial) {
    /* Wait until serial is ready */
  BTserial.begin(9600);
  Serial.println("BTserial started at 9600");
  dht.begin();
  if (!rtc.begin()) {
    Serial.println("Couldn't find RTC");
    while (1)
  if (rtc.lostPower()) {
    Serial.println("RTC lost power, lets set the time!");
    // following line sets the RTC to the date & time this sketch was compiled
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
  t1.every(1000 * 29, refreshDisplay);
  t2.every(1000, refreshTimer);
  t3.every(50, updateHue);
  refreshDisplay();
  t1.update();
  t2.update();
  t3.update();
  if (BTserial.available() > 0) {
    char received = BTserial.read();
    btBuffer += received;
    if (received == '|') {
      processCommand();
      btBuffer = "";
void updateHue() {
  if (colorMODE != 2)
    return;
  colorCHSV.sat = 255;
  colorCHSV.val = 255;
  if (colorCHSV.hue >= 255) {
    colorCHSV.hue = 0;
    colorCHSV.hue++;
  refreshDisplay();
void refreshDisplay() {
  switch (mode) {
    case 0:
      displayClock();
    case 1:
      displayTemperature();
    case 2:
      displayHumidity();
    case 3:
      displayScoreboard();
    case 4:
      // Time counter has it's own timer
    default:
void refreshTimer() {
  if (mode == 0 && blinkDots == 1) {
    displayDots(3);
  } else if (mode == 4 && timerRunning == 1 && timerValue < 6000) {
    timerValue++;
    byte m1 = (timerValue / 60) / 10;
    byte m2 = (timerValue / 60) % 10;
    byte s1 = (timerValue % 60) / 10;
    byte s2 = (timerValue % 60) % 10;
    displaySegments(0, s2);
    displaySegments(Seg2, s1);
    displaySegments(Seg3, m2);
    displaySegments(Seg4, m1);
    displayDots(0);
    FastLED.show();
void processCommand() {
  if (btBuffer.startsWith("RGBD")) {
    int R = getValue(btBuffer, ',', 1).toInt();
    int G = getValue(btBuffer, ',', 2).toInt();
    int B = getValue(btBuffer, ',', 3).toInt();
    int D = getValue(btBuffer, ',', 4).toInt();
    colorCRGB.red = R;
    colorCRGB.green = G;
    colorCRGB.blue = B;
    colorMODE = 0;
    if (D > 0) FastLED.setBrightness(D);
  } else if (btBuffer.startsWith("HSVD")) {
    int H = getValue(btBuffer, ',', 1).toInt();
    int S = getValue(btBuffer, ',', 2).toInt();
    int V = getValue(btBuffer, ',', 3).toInt();
    colorCHSV.hue = H;
    colorCHSV.sat = S;
    colorCHSV.val = V;
    colorMODE = 1;
  } else if (btBuffer.startsWith("RTC")) {
    int y = getValue(btBuffer, ',', 1).toInt();
    int m = getValue(btBuffer, ',', 2).toInt();
    int d = getValue(btBuffer, ',', 3).toInt();
    int h = getValue(btBuffer, ',', 4).toInt();
    int mm = getValue(btBuffer, ',', 5).toInt();
    int s = getValue(btBuffer, ',', 6).toInt();
    rtc.adjust(DateTime(y, m, d, h, mm, s));
    Serial.println("DateTime set");
  } else if (btBuffer.startsWith("CLOCK")) {
    mode = 0;
  } else if (btBuffer.startsWith("TEMPERATURE")) {
    mode = 1;
  } else if (btBuffer.startsWith("HUMIDITY")) {
    mode = 2;
  } else if (btBuffer.startsWith("SCOREBOARD")) {
    scoreLeft = getValue(btBuffer, ',', 1).toInt();
    scoreRight = getValue(btBuffer, ',', 2).toInt();
    mode = 3;
  } else if (btBuffer.startsWith("STARTTIMER")) {
    timerValue = 0;
    timerRunning = 1;
    mode = 4;
  } else if (btBuffer.startsWith("STOPTIMER")) {
    timerRunning = 0;
    mode = 4;
  } else if (btBuffer.startsWith("CHANGINGPATTERN")) {
    colorMODE = 2;
  refreshDisplay();
void displayClock() {
  DateTime now = rtc.now();
  byte h = now.hour();
  if (hourFormat == 12 && h > 12)
    h = h - 12;
  byte m = now.minute();
  displaySegments(0, m % 10);
  displaySegments(Seg2, m / 10);
  displaySegments(Seg3, h % 10);
  displaySegments(Seg4, (h / 10) == 0 ? 13 : (h / 10));
  displayDots(0);
  FastLED.show();
void displayTemperature() {
  Serial.println("In the temperature loop");
  float tmp = dht.readTemperature(temperatureMode == 'F' ? true : false);
  Serial.println("Temperature successfully read!");
  if (isnan(tmp)) {
    Serial.println("Failed to read from DHT sensor!");
    int tmp1 = tmp / 10;
    int tmp2 = ((int)tmp) % 10;
    displaySegments(Seg4, tmp1);
    displaySegments(Seg3, tmp2);
    displaySegments(Seg2, 10);
    displaySegments(0, (temperatureMode == 'F' ? 14 : 11));
    displayDots(1);
    FastLED.show();
void displayHumidity() {
  float hum = dht.readHumidity();
  if (isnan(hum)) {
    int hum1 = hum / 10;
    int hum2 = ((int)hum) % 10;
    displaySegments(Seg4, hum1);
    displaySegments(Seg3, hum2);
    displaySegments(0, 12);
    displayDots(1);
    FastLED.show();
void displayScoreboard() {
  byte s1 = scoreLeft % 10;
  byte s2 = scoreLeft / 10;
  byte s3 = scoreRight % 10;
  byte s4 = scoreRight / 10;
  displaySegments(0, s3);
  displaySegments(Seg2, s4);
  displaySegments(Seg3, s1);
  displaySegments(Seg4, s2);
  displayDots(2);
  FastLED.show();
void displayDots(byte dotMode) {
  const int Ind = 14 * NUM_LED_PRO_SEG;
  // dotMode: 0=Both on, 1=Both Off, 2=Bottom On, 3=Blink
  switch (dotMode) {
    case 0:
      LEDs[Ind] = colorMODE == 0 ? colorCRGB : colorCHSV;
      LEDs[1 + Ind] = colorMODE == 0 ? colorCRGB : colorCHSV;
    case 1:
      LEDs[Ind] = colorOFF;
      LEDs[1 + Ind] = colorOFF;
    case 2:
    case 3:
      LEDs[Ind] = (LEDs[Ind] == colorOFF) ? (colorMODE == 0 ? colorCRGB : colorCHSV) : colorOFF;
      LEDs[1 + Ind] = (LEDs[1 + Ind] == colorOFF) ? (colorMODE == 0 ? colorCRGB : colorCHSV) : colorOFF;
      FastLED.show();
    default:
void displaySegments(byte startindex, byte number) {
      __ __ __        __ __ __          __ __ __        12 13 14
    __        __    __        __      __        __    11        15
    __        __    __        __      __        __    10        16
    __        __    __        __  42  __        __    _9        17
      __ __ __        __ __ __          __ __ __        20 19 18
    __        65    __        44  43  __        21    _8        _0
    __        __    __        __      __        __    _7        _1
    __        __    __        __      __        __    _6        _2
      __ __ __       __ __ __           __ __ __       _5 _4 _3
  byte numbers[] = {
    0b00111111,  // 0
    0b00000110,  // 1
    0b01011011,  // 2
    0b01001111,  // 3
    0b01100110,  // 4
    0b01101101,  // 5
    0b01111101,  // 6
    0b00000111,  // 7
    0b01111111,  // 8
    0b01101111,  // 9
    0b01100011,  // º              10
    0b00111001,  // C(elcius)      11
    0b01011100,  // º lower        12
    0b00000000,  // Empty          13
    0b01110001,  // F(ahrenheit)   14
  for (byte i = 0; i < 7; i++)
    for (byte j = 0; j < NUM_LED_PRO_SEG; j++)
      LEDs[i * NUM_LED_PRO_SEG + startindex + j] = ((numbers[number] & 1 << i) == 1 << i) ? (colorMODE == 0 ? colorCRGB : colorCHSV) : colorOFF;
String getValue(String data, char separator, byte index) {
  byte found = 0;
  int strIndex[] = { 0, -1 };
  byte maxIndex = data.length() - 1;
  for (byte i = 0; i <= maxIndex && found <= index; i++) {
    if (data.charAt(i) == separator || i == maxIndex) {
      found++;
      strIndex[0] = strIndex[1] + 1;
      strIndex[1] = (i == maxIndex) ? i + 1 : i;
  return found > index ? data.substring(strIndex[0], strIndex[1]) : "";
I fixed it. I had to install the oldest version of the DHT library.
