Its a long messy code, but it has worked with that code already... it uses rx, tx for serial and a4 a5 for i2c, pin10 is input for button
#include <Wire.h>
#include <DFRobot_BT401.h>
int nextButton = 1;
int nextButtonWasPressed = 0;
String nowPlaying;
long lastDebounceTime = 0;
long debounceDelay = 200; //občutljivost gumba
int acolumn = 0;
int bcolumn = 1;
int ccolumn = 2;
int dcolumn = 3;
int ecolumn = 4;
int fcolumn = 5;
int gcolumn = 6;
int hcolumn = 7;
int icolumn = 8;
String inputText;
int inputText_len;
String smallDisplay = "33:54";
int smallDisplay_len = smallDisplay.length()+1;
constexpr size_t numColumns = 5; //number of bytes -columns for 1 character
//Pretty self-explenatory -here I store all my characters.
void getColumns(char c, uint8_t columns[numColumns]);
const uint8_t upperCase[][numColumns] PROGMEM = {
{0X7E, 0X11, 0X11, 0X11, 0X7E}, // Column codes for 'A'
{0X7F, 0X49, 0X49, 0X49, 0X36}, // Column codes for 'B'
{0X3E, 0X41, 0X41, 0X41, 0X22}, // Column codes for 'C'
{0X7F, 0X41, 0X41, 0X22, 0X1C}, // Column codes for 'D'
{0X7F, 0X49, 0X49, 0X49, 0X41}, // Column codes for 'E'
{0X7F, 0X09, 0X09, 0X09, 0X01}, // Column codes for 'F'
{0X3E, 0X41, 0X49, 0X49, 0X7A}, // Column codes for 'G'
{0X7F, 0X08, 0X08, 0X08, 0X7F}, // Column codes for 'H'
{0X00, 0X41, 0X7F, 0X41, 0X00}, // Column codes for 'I'
{0X20, 0X40, 0X41, 0X3F, 0X01}, // Column codes for 'J'
{0X7F, 0X08, 0X14, 0X22, 0X41}, // Column codes for 'K'
{0X7F, 0X40, 0X40, 0X40, 0X40}, // Column codes for 'L'
{0X7F, 0X02, 0X0C, 0X02, 0X7F}, // Column codes for 'M'
{0X7F, 0X04, 0X08, 0X10, 0X7F}, // Column codes for 'N'
{0X3E, 0X41, 0X41, 0X41, 0X3E}, // Column codes for 'O'
{0X7F, 0X09, 0X09, 0X09, 0X06}, // Column codes for 'P'
{0X3E, 0X41, 0X41, 0X61, 0X3E}, // Column codes for 'Q'
{0X7F, 0X09, 0X19, 0X29, 0X46}, // Column codes for 'R'
{0X46, 0X49, 0X49, 0X49, 0X31}, // Column codes for 'S'
{0X01, 0X01, 0X7F, 0X01, 0X01}, // Column codes for 'T'
{0X3F, 0X40, 0X40, 0X40, 0X3F}, // Column codes for 'U'
{0X07, 0X18, 0X60, 0X18, 0X07}, // Column codes for 'V'
{0X3F, 0X40, 0X38, 0X40, 0X3F}, // Column codes for 'W'
{0X63, 0X14, 0X08, 0X14, 0X63}, // Column codes for 'X'
{0X07, 0X08, 0X70, 0X08, 0X07}, // Column codes for 'Y'
{0X61, 0X51, 0X49, 0X45, 0X43} // Column codes for 'Z'
const uint8_t lowerCase[][numColumns] PROGMEM = {
{0X20, 0X54, 0X54, 0X54, 0X78}, // Column codes for 'a'
{0X7F, 0X48, 0X48, 0X48, 0X30}, // Column codes for 'b'
{0X38, 0X44, 0X44, 0X44, 0X44}, // Column codes for 'c'
{0X30, 0X48, 0X48, 0X48, 0X7F}, // Column codes for 'd'
{0X38, 0X54, 0X54, 0X54, 0X58}, // Column codes for 'e'
{0X00, 0X08, 0X7E, 0X09, 0X02}, // Column codes for 'f'
{0X48, 0X54, 0X54, 0X54, 0X3C}, // Column codes for 'g'
{0X7F, 0X08, 0X08, 0X08, 0X70}, // Column codes for 'h'
{0X00, 0X00, 0X7A, 0X00, 0X00}, // Column codes for 'i'
{0X20, 0X40, 0X40, 0X39, 0X00}, // Column codes for 'j'
{0X00, 0X7F, 0X10, 0X28, 0X44}, // Column codes for 'k'
{0X00, 0X41, 0X7F, 0X40, 0X00}, // Column codes for 'l'
{0X7C, 0X04, 0X18, 0X04, 0X7C}, // Column codes for 'm'
{0X7C, 0X08, 0X04, 0X04, 0X78}, // Column codes for 'n'
{0X30, 0X48, 0X48, 0X30, 0X00}, // Column codes for 'o'
{0X7C, 0X14, 0X14, 0X14, 0X08}, // Column codes for 'p'
{0X7F, 0X04, 0X04, 0X04, 0X03}, // Column codes for 'q'
{0X7C, 0X08, 0X04, 0X04, 0X08}, // Column codes for 'r'
{0X48, 0X54, 0X54, 0X54, 0X24}, // Column codes for 's'
{0X04, 0X04, 0X3F, 0X44, 0X24}, // Column codes for 't'
{0X3C, 0X40, 0X40, 0X40, 0X3C}, // Column codes for 'u'
{0X1C, 0X20, 0X40, 0X20, 0X1C}, // Column codes for 'v'
{0X3C, 0X40, 0X30, 0X40, 0X3C}, // Column codes for 'w'
{0X44, 0X28, 0X10, 0X28, 0X44}, // Column codes for 'x'
{0X04, 0X48, 0X30, 0X18, 0X04}, // Column codes for 'y'
{0X44, 0X64, 0X54, 0X4C, 0X44} // Column codes for 'z'
const uint8_t numerals[][numColumns] PROGMEM = {
{0X3E, 0X45, 0X49, 0X51, 0X3E}, // Column codes for '0'
{0X00, 0X42, 0X7F, 0X40, 0X00}, // Column codes for '1'
{0X42, 0X61, 0X51, 0X49, 0X46}, // Column codes for '2'
{0X22, 0X41, 0X49, 0X49, 0X36}, // Column codes for '3'
{0X18, 0X14, 0X12, 0X7F, 0X10}, // Column codes for '4'
{0X27, 0X45, 0X45, 0X45, 0X39}, // Column codes for '5'
{0X3E, 0X49, 0X49, 0X49, 0X30}, // Column codes for '6'
{0X01, 0X71, 0X09, 0X05, 0X03}, // Column codes for '7'
{0X36, 0X49, 0X49, 0X49, 0X36}, // Column codes for '8'
{0X06, 0X49, 0X49, 0X49, 0X3E} // Column codes for '9'
const uint8_t symbolsa[][numColumns] PROGMEM = {
{0X00, 0X00, 0X5F, 0X00, 0X00}, // Column codes for '!'
{0X00, 0X03, 0X00, 0X03, 0X00}, // Column codes for '"'
{0X14, 0X7F, 0X14, 0X7F, 0X14}, // Column codes for '#'
{0X24, 0X2A, 0X7F, 0X2A, 0X12}, // Column codes for '$'
{0X23, 0X13, 0X08, 0X64, 0X62}, // Column codes for '%'
{0X36, 0X49, 0X55, 0X22, 0X50}, // Column codes for '&'
{0X04, 0X02, 0X02, 0X01, 0X00}, // Column codes for '''
{0X00, 0X1C, 0X22, 0X41, 0X00}, // Column codes for '('
{0X00, 0X41, 0X22, 0X1C, 0X00}, // Column codes for ')'
{0X14, 0X08, 0X3E, 0X08, 0X14}, // Column codes for '*'
{0X08, 0X08, 0X3E, 0X08, 0X08}, // Column codes for '+'
{0X00, 0X00, 0X50, 0X30, 0X00}, // Column codes for ','
{0X08, 0X08, 0X08, 0X08, 0X08}, // Column codes for '-'
{0X00, 0X60, 0X60, 0X00, 0X00}, // Column codes for '.'
{0X20, 0X10, 0X08, 0X04, 0X02} // Column codes for '/'
const uint8_t symbolsb[][numColumns] PROGMEM = {
{0X00, 0X7F, 0X41, 0X41, 0X00}, // Column codes for '['
{0X02, 0X04, 0X08, 0X10, 0X20}, // Column codes for '\'
{0X00, 0X41, 0X41, 0X7F, 0X00}, // Column codes for ']'
{0X04, 0X02, 0X01, 0X02, 0X04}, // Column codes for '^'
{0X40, 0X40, 0X40, 0X40, 0X40}, // Column codes for '_'
{0X00, 0X01, 0X02, 0X04, 0X00} // Column codes for '`'
const uint8_t symbolsc[][numColumns] PROGMEM = {
{0X08, 0X36, 0X41, 0X41, 0X00}, // Column codes for '{'
{0X00, 0X00, 0X7F, 0X00, 0X00}, // Column codes for '|'
{0X00, 0X41, 0X41, 0X36, 0X08}, // Column codes for '}'
{0X01, 0X02, 0X01, 0X20, 0X00}, // Column codes for '~'
const uint8_t equalSymbol [numColumns] PROGMEM = {0x14, 0x14, 0x14, 0x14, 0x14};
const uint8_t afnaSymbol [numColumns] PROGMEM = {0x32, 0x49, 0x71, 0x41, 0x3E};
const uint8_t space[numColumns] PROGMEM = {0x00, 0x00, 0x00, 0x00, 0x00};
const uint8_t unknown[numColumns] PROGMEM = {0x00, 0x00, 0x00, 0x00, 0x00};
DFRobot_BT401 bt;
pinMode(10, INPUT_PULLUP); //next button
/*Delay 2s for the BT401 to start*/
delay(2000);
while(!bt.begin(Serial)){
bt.setVOl(30);
bt.switchFunction(bt.eUDisk);
delay(100);
bt.setPlayMode(bt.eDeviceCycle);
nextButton = digitalRead(10);
if (nextButton != nextButtonWasPressed) {
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
if (nextButton == 0 && nextButtonWasPressed == 0)
bt.next();
nextButtonWasPressed = 1;
if(nextButtonWasPressed == 1)
int acolumn = 0;
int bcolumn = 1;
int ccolumn = 2;
int dcolumn = 3;
int ecolumn = 4;
int fcolumn = 5;
int gcolumn = 6;
int hcolumn = 7;
int icolumn = 8;
if(nextButton == 1)
//String inputText = (bt.getFilename());
nowPlaying = (bt.getFilename());
inputText = nowPlaying;
inputText_len = inputText.length() + 1;
//bt.playControl(bt.ePlay);
char inputText_array[inputText_len];
inputText.toCharArray(inputText_array, inputText_len);
//Serial only for troubleshooting -I can remove it when it works.
uint8_t ahr[numColumns];
getColumns(inputText[acolumn], ahr); //This would store all 5 bytes (columns)of letter A in "xxx"
uint8_t bhr[numColumns];
getColumns(inputText[bcolumn], bhr); //This would store all 5 bytes (columns)of letter A in "xxx"
uint8_t chr[numColumns];
getColumns(inputText[ccolumn], chr); //This would store all 5 bytes (columns)of letter A in "xxx"
uint8_t dhr[numColumns];
getColumns(inputText[dcolumn], dhr); //This would store all 5 bytes (columns)of letter A in "xxx"
uint8_t ehr[numColumns];
getColumns(inputText[ecolumn], ehr); //This would store all 5 bytes (columns)of letter A in "xxx"
uint8_t fhr[numColumns];
getColumns(inputText[fcolumn], fhr); //This would store all 5 bytes (columns)of letter A in "xxx"
uint8_t ghr[numColumns];
getColumns(inputText[gcolumn], ghr); //This would store all 5 bytes (columns)of letter A in "xxx"
uint8_t hhr[numColumns];
getColumns(inputText[hcolumn], hhr); //This would store all 5 bytes (columns)of letter A in "xxx"
uint8_t ihr[numColumns];
getColumns(inputText[icolumn], ihr); //This would store all 5 bytes (columns)of letter A in "xxx"
char smallDisplay_array[smallDisplay_len];
smallDisplay.toCharArray(smallDisplay_array, smallDisplay_len);
uint8_t smla[numColumns];
getColumns(smallDisplay[0], smla); //This would store all 5 bytes (columns)of letter A in "xxx"
uint8_t smlb[numColumns];
getColumns(smallDisplay[1], smlb); //This would store all 5 bytes (columns)of letter A in "xxx"
uint8_t smlc[numColumns];
getColumns(smallDisplay[2], smlc); //This would store all 5 bytes (columns)of letter A in "xxx"
uint8_t smld[numColumns];
getColumns(smallDisplay[3], smld); //This would store all 5 bytes (columns)of letter A in "xxx"
uint8_t smle[numColumns];
getColumns(smallDisplay[4], smle); //This would store all 5 bytes (columns)of letter A in "xxx"
//COMMANDS TO SET UP THE DISPLAY
Wire.begin(); // join i2c bus
Wire.beginTransmission(0x3C); // transmit to device
Wire.write(0x55); // set_mode -normal video, mixed mode, MUX 1:8
Wire.endTransmission(); // stop transmitting
Wire.write(0x3e); // RAM access
Wire.write(0x7c); //set start bank 0
Wire.write(0x62); //device select
//WRITING TO DISPLAY STARTS HERE
Wire.write(0x0F); //load x address
Wire.write(bhr[3]); // DATA column 10
Wire.write(bhr[2]); // DATA column 9
Wire.write(bhr[1]); // DATA column 8
Wire.write(bhr[0]); // DATA column 7
Wire.write(0x00); // DATA column 6
Wire.write(ahr[4]); // DATA column 5
Wire.write(ahr[3]); // DATA column 4
Wire.write(ahr[2]); // DATA column 3
Wire.write(ahr[1]); // DATA column 2
Wire.write(ahr[0]); // DATA column 1
Wire.write(0x05); //load x address
Wire.write(dhr[1]); // DATA column 20
Wire.write(dhr[0]); // DATA column 19
Wire.write(0x00); // DATA column 18
Wire.write(chr[4]); // DATA column 17
Wire.write(chr[3]); // DATA column 16
Wire.write(chr[2]); // DATA column 15
Wire.write(chr[1]); // DATA column 14
Wire.write(chr[0]); // DATA column 13
Wire.write(0x00); // DATA column 12
Wire.write(bhr[4]); // DATA column 11
Wire.write(0x00); //load x address
Wire.write(0x00); // DATA MISSING COLUMN -BLANK
Wire.write(0x00); // DATA column 24
Wire.write(dhr[4]); // DATA column 23
Wire.write(dhr[3]); // DATA column 22
Wire.write(dhr[2]); // DATA column 21
Wire.write(0x61); //device select
Wire.write(0x1f); //load x address
Wire.write(fhr[3]); // DATA column 34
Wire.write(fhr[2]); // DATA column 33
Wire.write(fhr[1]); // DATA column 32
Wire.write(fhr[0]); // DATA column 31
Wire.write(0x00); // DATA column 30
Wire.write(ehr[4]); // DATA column 39
Wire.write(ehr[3]); // DATA column 28
Wire.write(ehr[2]); // DATA column 27
Wire.write(ehr[1]); // DATA column 26
Wire.write(ehr[0]); // DATA column 25
Wire.write(0x14); //load x address
Wire.write(hhr[2]); // DATA column 45
Wire.write(hhr[1]); // DATA column 44
Wire.write(hhr[0]); // DATA column 43
Wire.write(0x00); // DATA column 42
Wire.write(ghr[4]); // DATA column 41
Wire.write(ghr[3]); // DATA column 40
Wire.write(ghr[2]); // DATA column 39
Wire.write(ghr[1]); // DATA column 38
Wire.write(ghr[0]); // DATA column 37
Wire.write(0x00); // DATA column 36
Wire.write(fhr[4]); // DATA column 35
Wire.write(0x0A); //load x address
Wire.write(0x00); // DATA column 55
Wire.write(0x00); // DATA column 54
Wire.write(ihr[4]); // DATA column 53
Wire.write(ihr[3]); // DATA column 52
Wire.write(ihr[2]); // DATA column 51
Wire.write(ihr[1]); // DATA column 50
Wire.write(ihr[0]); // DATA column 49
Wire.write(0x00); // DATA column 48
Wire.write(hhr[4]); // DATA column 47
Wire.write(hhr[3]); // DATA column 46
//MALI DISPLAY -URA
//ČETRTA
Wire.write(0x60); //device select
Wire.write(0x00);
Wire.write(smle[4]); // DATA column 50
Wire.write(smle[3]); // DATA column 49
Wire.write(smle[2]); // DATA column 48
Wire.write(smle[1]); // DATA column 47
Wire.write(smle[0]); // DATA column 46
//TRETJA
Wire.write(0x10); //load x address
Wire.write(smld[4]); // DATA column 50
Wire.write(smld[3]); // DATA column 49
Wire.write(smld[2]); // DATA column 48
Wire.write(smld[1]); // DATA column 47
Wire.write(smld[0]); // DATA column 50
//DVOPIČJE ALI ČRTA
Wire.write(0x15); //load x address
Wire.write(0x22); // 0x22 je dvopičje, 0x7F je črta
//DRUGA
Wire.write(0x16); //load x address
Wire.write(smlb[4]); // DATA column 50
Wire.write(smlb[3]); // DATA column 49
Wire.write(smlb[2]); // DATA column 48
Wire.write(smlb[1]); // DATA column 47
Wire.write(smlb[0]); // DATA column 50
//PRVA
Wire.write(0x1c); //load x address
Wire.write(smla[4]); // DATA column 50
Wire.write(smla[3]); // DATA column 49
Wire.write(smla[2]); // DATA column 48
Wire.write(smla[1]); // DATA column 47
Wire.write(smla[0]); // DATA column 50
if(inputText_len > 9 && icolumn < inputText_len){
acolumn = (acolumn + 1);
bcolumn = (bcolumn + 1);
ccolumn = (ccolumn + 1);
dcolumn = (dcolumn + 1);
ecolumn = (ecolumn + 1);
fcolumn = (fcolumn + 1);
gcolumn = (gcolumn + 1);
hcolumn = (hcolumn + 1);
icolumn = (icolumn + 1);
delay(350);
}else{
acolumn = 0;
bcolumn = 1;
ccolumn = 2;
dcolumn = 3;
ecolumn = 4;
fcolumn = 5;
gcolumn = 6;
hcolumn = 7;
icolumn = 8;
//I don`t get this part fully.
void getColumns(char c, uint8_t columns[numColumns]) {
switch (c) {
case 'A'...'Z':
memcpy_P(&columns[0], &upperCase[c - 'A'][0], numColumns); //I think that this "A" changes depending if it`s case A or B or C ... something like if it`s "A" do that, if it`s "B" do that...
case 'a'...'z':
memcpy_P(&columns[0], &lowerCase[c - 'a'][0], numColumns);
case '0'...'9':
memcpy_P(&columns[0], &numerals[c - '0'][0], numColumns);
case ' ':
memcpy_P(&columns[0], &space[0], numColumns);
case '!'...'/':
memcpy_P(&columns[0], &symbolsa[c - '!'][0], numColumns);
case '['...'`':
memcpy_P(&columns[0], &symbolsb[c - '['][0], numColumns);
case '{'...'~':
memcpy_P(&columns[0], &symbolsc[c - '{'][0], numColumns);
case '=':
memcpy_P(&columns[0], &equalSymbol[0], numColumns);
case '@':
memcpy_P(&columns[0], &afnaSymbol[0], numColumns);
default:
memcpy_P(&columns[0], &unknown[0], numColumns);
