Nano Not Uploading
I have been trying to upload a sketch to my Nanos and have been unable to for weeks now, please can someone point me in the right direction?
Green_Corridor_6
You exceeded your current plan quota, you can only view your sketches. To make changes, upgrade your plan or delete something.
Upgrade Plan
    Green_Corridor_6.ino
    ReadMe.adoc
Executing command: exit status 1
/home/builder/opt/arduino-builder/arduino-builder -compile -core-api-version 10611 -hardware /home/builder/opt/arduino-builder/hardware -hardware /home/builder/.arduino15/packages -tools /home/builder/opt/arduino-builder/tools -tools /home/builder/.arduino15/packages -built-in-libraries /home/builder/opt/libraries/latest -logger humantags -fqbn arduino:megaavr:nona4809:mode=on -build-cache /tmp -build-path /tmp/603225900/build -verbose -prefs runtime.tools.bossac.path=/home/builder/.arduino15/packages/arduino/tools/bossac/1.7.0 -prefs runtime.tools.arduino101load.path=/home/builder/.arduino15/packages/Intel/tools/arduino101load/2.0.1 -prefs runtime.tools.core2-32-poky-linux.path=/home/builder/.arduino15/packages/Intel/tools/core2-32-poky-linux/1.6.2+1.0 -prefs runtime.tools.avrdude.path=/home/builder/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino16 -prefs runtime.tools.x86-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/x86-linux-gcc/7.2.0 -prefs runtime.tools.linuxuploader.path=/home/builder/.arduino15/packages/arduino/tools/linuxuploader/1.5.1 -prefs runtime.tools.i586-poky-linux-uclibc.path=/home/builder/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0 -prefs runtime.tools.openocd.path=/home/builder/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs runtime.tools.dfu-util.path=/home/builder/.arduino15/packages/arduino/tools/dfu-util/0.9.0-arduino1 -prefs runtime.tools.arm-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-linux-gcc/4.9.3 -prefs runtime.tools.arm-none-eabi-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs runtime.tools.arc-elf32.path=/home/builder/.arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1 -prefs runtime.tools.flashpack.path=/home/builder/.arduino15/packages/Intel/tools/flashpack/2.0.0 -prefs runtime.tools.nrf5x-cl-tools.path=/home/builder/.arduino15/packages/arduino/tools/nrf5x-cl-tools/9.3.1 -prefs runtime.tools.arduinoOTA.path=/home/builder/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs runtime.tools.sketchUploader.path=/home/builder/.arduino15/packages/Intel/tools/sketchUploader/1.6.2+1.0 -prefs runtime.tools.avr-gcc.path=/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5 -prefs runtime.tools.CMSIS-Atmel.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0 -prefs runtime.tools.CMSIS.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS/4.5.0 -libraries /tmp/603225900/custom -libraries /tmp/603225900/pinned /tmp/603225900/Green_Corridor_6
Sketch uses 1718 bytes (3%) of program storage space. Maximum is 49152 bytes.
Global variables use 22 bytes (0%) of dynamic memory, leaving 6122 bytes for local variables. Maximum is 6144 bytes.
Programming with: Serial
Restarting in bootloader mode
Get port list before reset
[COM7]
Touching port COM7 at 1200bps
Set DTR off
Flashing with command:C:/Users/XXXX/.arduino-create/arduino/avrdude/6.3.0-arduino16/bin/avrdude.exe -CC:/Users/JXXXX/.arduino-create/arduino/avrdude/6.3.0-arduino16/etc/avrdude.conf -v -patmega4809 -cjtag2updi -PCOM7 -b115200 -e -D -Uflash:w:C:/Users/XXXX/AppData/Local/Temp/arduino-create-agent507297614/Green_Corridor_6.hex:i -Ufuse2:w:0x01:m -Ufuse5:w:0xC9:m -Ufuse8:w:0x00:m {upload.extra_files}
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:/Users/XXXX/.arduino-create/arduino/avrdude/6.3.0-arduino16/etc/avrdude.conf"
Using Port : COM7
Using Programmer : jtag2updi
Overriding Baud Rate : 115200
avrdude: jtagmkII_getsync(): sign-on command: status -1
avrdude: jtagmkII_getsync(): timeout/error communicating with programmer (status -1)
avrdude done. Thank you.
Which Nano board do you have? I can see that you have the Arduino Web Editor configured for the Nano Every, but there are several other Arduino Nano boards, including the classic Nano (based on the ATmega328P microcontroller) and the Nano 33 IoT.
Sigh, I just knew this was going to happen the instant they released three new boards with the word "Nano" in the name, but with nothing other than the name and shape of the board the same as the classic nano. These three new boards each use completely different architectures (from both the classic nano, and eachother). What were they thinking? They must know that people constantly confuse even the Due with the Duemillanove (since most people don't know that the latter is 2009 in italian and the latter is 2), and that people think the Uno and Uno WiFi Rev. 2 are the same board. And what do they do? Release three mutually incompatible boards with virtually the same name.
