Nano on Windows XP cannot find USB2.0-Serial driver
I have Mega and Nano boards. While on Win7 I can use both and everything works fine, on all my various WinXP only Mega works fine. Nano always comes up with installation issue: "USB2.0-Serial" does not have proper drivers - question mark in Device manager. I have tried MANY drivers (from original Adruino package, from FTDI page, many older versions, searched Google for hours and trying a lot), no success at all.
This is perhaps WinXP (tried on more versions, both Pack2 and Pack3) issue with installing virtual COM port for Nano (while Mega works perfectly). Please advice me what and how to install on WinXP to be able to use Nano as well.
http://www.wch.cn/downloads.php?name=pro&proid=5
1- The structure of the translated English page.
2- Locate your version of Windows, download and install,
It will create a virtual port,
Set that port and start using the arduino program...
I have XP sp3. My Nano 3.0 will not communicate since upgrading my IDE to 1.6.3. Tried everything in the troubleshooting section.
I downloaded a driver from VCP Drivers - FTDI and it worked.
Since this thread is still one of the top Google hits for this problem, I figure I would add this:
I had the same problem trying to install the driver for an Arduino Nano on Windows XP. I tried pretty much everything, but only this worked:
https://arduino-info.wikispaces.com/Nano-USB-Drivers
Probably, you have Chinese Nano with CH340 USB/serial converter, according the link you've posted.
Previous discussion is about FTDI FT232RL chip as genuine Nano has. It is different and same about driver. It has nothing with the XP directly.
Hi
ARDUINO IS UNSTABLE!!!!!!!!!!!!!!!!
Ok now you can throw rocks at me...thousands of users with the same problems.
I use 3 computers:
1.Win7...32BIT
2.Win7...64BIT
3.Win10...no need to say but 64 bit
I started to upgrade from ARDUINO 1.8.2 to 1.8.5
The last week I spend hours on each pc to get the downloading to work AGAIN.
The COM PORT shows in TOOLS and is ticked but i get the STK500 SYNC ERROR after the upgrade.
Then I start following the list of possible fixes .. uninstall driver...re install..re boot pc...swap cable..swap
arduino..uinstall arduino ...uninstall driver..install driver first ...now install arduino..re boot pc...repeat the list
start re doing all above in a changed order.
Then all for no apparent reason the usb port works and download the HEX file, now do all above on pc2 and
pc3 over and over and over...... until it works.
Once i get it to work AGAIN I love it...but
mikedb:
Hi
Unstable?
Sounds more like operator error to me.
Windows 10 64-bit laptop #1
Windows 7 64-bit pc #2
Linux Mint 18 64-bit pc #3
all work
There was a boards.txt change and you may be the victim of that. Try Nano (old bootloader) when selecting the board (if that option is available).
I changed the selected board to Nano (with old Bootloader) and it worked for me.
