I just recently bought 3 Nano V3.0, Nano Board ATmega328P 5V 16M Micro-Controller Board Compatible with Arduino IDE (Nano x 3 with USB Cable) by LAFVIN and I tried to create a humidity and temperature display on my breadboard with it. At first, I plugged it in, changed the board to Arduino Nano, but the usual Port 4 with the board was not there on the port list. I looked something up and installed the CH340 driver to try to fix things and it now shows up at port 5. Whenever I tried downloading code into the nano, it either seemed to download except it has no function with other components, it had a never ending cycle of trying to download, or it just had an error message and refused to load at all. I have already tried using it with the old bootloader setting with no avail. The error message:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x82
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x82
avrdude done. Thank you.
Problem uploading to board.
#include <LiquidCrystal.h>
#include <DHT.h>
#define Type DHT11
int rs = 7;
int en = 8;
int d4 = 9;
int d5 = 10;
int d6 = 11;
int d7 = 12;
int dhtPn = 6;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
DHT dht(dhtPn, Type);
float humidity;
float temperature;
int dt = 500;
lcd.begin(16, 2);
dht.begin();
delay(dt);
humidity = dht.readHumidity();
temperature = dht.readTemperature(true);
lcd.setCursor(0, 0);
lcd.clear();
lcd.print("Humid: ");
lcd.print(humidity);
lcd.print("%");
lcd.setCursor(0, 1);
lcd.print("Temp: ");
lcd.print(temperature);
lcd.print("F");
delay(dt);
