nano power problem
If i run a nano from the USB cable and assign an input as pullup then it works fine.
If I use the external Vin at 7v the pullup doesnt workj and the pin stays low.
If I attach the USB and the external 7v it works again but as the pullup pin is being switched quickly (reed switch to earth), it creates a lot of noise on the power lines.
I need to use the external powersupply...
All the earths look good. The nano outputs its 5v and 3v3 so I dont think there is any regulator damage.
Why would the pullup stop working from Vin?
You need to post your program.
What have you connected to the nano?
...R
7 volt sounds like a little bit too less. Or Your 7 volt is discharged.
You can make a test. Connect only the 7 volt to Vin and measure at the 5 volt pin. What do You see?
Appreciate the comments and it made me relook at the cct.
I had a pcb tracking error and one of the pwm outputs was sitting on the +v which messed up the Vin.
Not sure the effect it created but its fixed for now. One to ponder.
