Nano problems with update 1.8.7
I can compile and upload my (rather large) program to the Nano using IDEv1.8.5 on a Linux PC, but the same on IDEv1.8.7 gave me the following errors...
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/home/phil/arduino-1.8.7/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/home/phil/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyUSB0
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I presumed it was the baud speed of the upload, so I changed the baud rate from 115200 to 57600 in the file arduino-1.8.7/hardware/arduino/avr/boards.txt
## Arduino Nano w/ ATmega328P
nano.menu.cpu.atmega328=ATmega328P
nano.menu.cpu.atmega328.upload.maximum_size=30720
nano.menu.cpu.atmega328.upload.maximum_data_size=2048
nano.menu.cpu.atmega328.upload.speed=57600
nano.menu.cpu.atmega328.bootloader.low_fuses=0xFF
nano.menu.cpu.atmega328.bootloader.high_fuses=0xDA
nano.menu.cpu.atmega328.bootloader.extended_fuses=0xFD
nano.menu.cpu.atmega328.bootloader.file=optiboot/optiboot_atmega328.hex
nano.menu.cpu.atmega328.build.mcu=atmega328p
I can now upload the program to the Nano using 1.8.7, but the nano simply reboots itself 3 times and dies until restarted.
I therefore currently have to use the 1.8.5 version. My only thought at this moment is that the available RAM is too low for the 1.8.7 version. I will do some testing, but thought I would post first in case the problem is bigger and known by someone, or I solve it and forget to update this.
(deleted)
