Nano regulator blowing
:confused: need some help to find my problem
Iv made a controller to control the solenoids in my gearbox
The unit works fine but here is the problem
I have tryed to convert to a nano and everytime the regulator blows
The nano needs to control 2 relays and both turn on or off depanding on what gear i am in
And obviously its running around 12 to 13v dc from car battery
Can anyone help me with ideas on what to check so i can work out why the nano reg keeps blowing
Here are some pictures
:confused: bu
:frowning:
Check for short circuits
You should be controlling relays which control the bigger relays.
How about a schematic showing how things are connected, and a clear shot looking down on the relay?
Sounds like the jumpers you have used are perhaps letting 12V connect to the 5V supply and damaging the Nano.
Or, letting 5V connect to Gnd.
arduino nano pins
VIN = Car ignition switched
GND = Car Gnd
A0 = Car gear input sensor
D2 = I1 on relay board
D3 = I2 on relay board
GND = GND on relay board
5V = 5V input on relay board
Relay board: (sainsmart hl-25s v1.0)
JdVcc jumpered to Vcc
Common on both relays connects to Car IGN 12V
Relay 1 NO contact to Solinoid 1
Relay 2 NO contact to Solinoid 2
sorry I don't have a Circuit designer handy to draw you a visual pic
the setup runs fine under usb power relays operate as expected.
as soon the cars power and ground are hooked up to the nano the regs overheat (no other connections to the car are made )
we have one in the car and running with a freetronics full size arduino and separate relay boards and its been fine from the moment it was installed.
we switched to nano arduinos to reduce the footprint of the box
wiring is exactly the same as the freetronics one we have working yet we have blown 4 different nanos up when power applied.
( btw im helping joel work through the problem )
quadie:
And by doing that you power the relays from the Arduino. Which the regulator on no Arduino can handle, they are all limited in the amount of current they can supply. Especially when you power the Arduino from the 12V of a car (which can be 14-15V!). The Arduino alone is a big enough load already. So remove that jumper and get yourself a separate 5V regulator for the relay's. I would go for a DC-DC converter not to wast an awful lot of power in the regulator.
And bleg, I do hate those overly complicated opto relay boards. :confused:
I assume you have a pencil, paper and a cell phone camera? That works too.
joeltaylor:
When it is working fine what voltage supply are you using
quadie:
What 5V input i cant see one on that board.
Do you mean Vcc
Some have a 5V OUTPUT though.
First blown circuit should have been a warning.
Does it blow when you turn it on or when you crank the engine ?
Looking around , although nano has a specified range of 6 to 20V in.
There a few complaints of them smoking when used with a 12V supply.
Voltage levels in a car can also be crazy high with regards to brief spikes.
Yes, and looking at his pictures the input cap appears do have blown off.
Looking at one of mine i notice its rated at 16 V.
Get a plug-in cigaret lighter style USB charger, and use a USB lead between this and the Nano.
Those switching regulators output 5volt with enough current to power the Arduino and two relays.
You most likely can use the Nanos with the blown regulators.
Leo..
If you have 12V available, why not use relays with 12V coils?
Currently using a freetronics board and 2 single relays and it works fine of 12v ign to vin But the nano just heats up like crazy then dies
Do you still use the same relays? Then you, you're going to blow the regulator. Like I said, the onboard regulator is just a tiny linear regulator which can barely power the Nano when connected to "high" voltages like 12V - 14V from a car. So just switch to an external regulator.
Yeah still using this relay
Would the nano work if i used a 7506 reg to power it
Wired the reg up and it will put out 6.18v would that be enough to power everything
Or should i just stick to using the usb input for power
No, not with a 7806. You could use a 7805 but you need a proper heatsink. But just throw out those linear regulators! Those relays have a nominal current of 90mA each. So the whole thing is around 250mA (not counting for inrush current and other devices on the 5V). So the regulator need to drop around 14v - 5V = 9V. 9V x 250mA = 2,25W. That's a significant amount of heat to dissipate!
Just go for a DC-DC converter (like a car USB charger) and you don't have a problem. You can even use the blown Nano's. Maybe decouple the Nano from the relays via a (Schottky) diode.
