Nano resets during setup()
Hi guys,
I have a simple program that should send a msg to another arduino when something happens.
Worked perfectly for a few weeks, but suddenly it resets during setup().
Here's the code:
  Arduino NANO + NRF24L01
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <RF24Network.h>
#define CE   9
#define CSN 10
#define SENSOR_1 3
RF24 radio(CE, CSN); // Create a Radio
RF24Network network(radio);
const uint16_t this_node = 02;
const uint16_t master00 = 00;
char dataToSend[4] = "Pos2";
bool jam = false;
int val1 = 0;
int val2 = 0;
int val3 = 0;
int val4 = 0;
int val5 = 0;
int threshold = 150;
int flag = 0;
unsigned long startTime;
unsigned long stopTime;
unsigned long elapsedTime;
unsigned long interval = 5000; // how long in ms should the sensor be active to detect a jam
  Serial.println("Tx Starting");
  SPI.begin();
  radio.begin();
  network.begin(90, this_node);
  radio.setDataRate( RF24_250KBPS );
  radio.setRetries(3, 5); // delay, count
  digitalWrite(SENSOR_1, LOW);                 //change to analog with light barriers
  network.update();
  val1 = digitalRead(SENSOR_1);
  if (val1 == HIGH) {
    jam = true;
  //===== Sending =====//
  if (jam) {   // If a jam is detected, send a message!
    Serial.println("Jam detected");
    RF24NetworkHeader header(master00, '2');   // (Address where the data is going)
    network.write(header, &dataToSend, sizeof(dataToSend)); // Send the data
    Serial.println(dataToSend);
    delay (1000);
    jam = false;
The serial monitor just gives me this repeatedly:
Tx St⸮Tx St⸮Tx St⸮Tx St⸮Tx St⸮Tx St⸮
I should mention that I have another Nano with the same code on it, using the same wireless module and it still works perfectly.
Is this Nano fried or am I missing something?
Have you tried to upload a different sketch to the affected Nano?
groundFungus:
Just tried the digitalReadSerial example.
Got this:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
Changed the usb port on the PC, uploaded successfully, printed 0s and 1s ok, but sometimes there would be a ? after them.
Uploaded my code again, got the same thing in serial monitor again.
I thought it could be a faulty wireless module, but I switched them between the working Nano and this one, same thing happens.
Just a quick update.
Fixed it by disconnecting everything from the Nano and uploading the schetch again. Works fine now.
