Hi Guys,
I bought the new Nano RP2040 Connect board and I had a lot of problems with drivers, in few words I followed any official guide to install the specific driver but the board is still not well recognized (on device manager I have the label "Nano RP2040 Connect" with the yellow exclamation mark and no driver associated). Indeed if i try to upload I always get the below general Error for sketch uploading:
rp2040load 1.0.1 - compiled with go1.15.8
Errore durante il caricamento dello sketch
So following the guide at "https://support.arduino.cc/hc/en-us/articles/4404168794514-Nano-RP2040-Connect-not-being-detected-on-USB-port"
I found the workaround to upload the sketches, if I activate the BOOTLOADER MODE every upload goes fine, but if I would like to use the cloud service I am not able since the board is not recognized again... Did you have any suggestion ?
How is possible I have to work in Bootloader mode and not as standard way ? I tried with different windows version but the problem persists.
Thanks a lot.
