Nano sequencer struggles
hi guys - i really need an extra set of eyes to look over this rough sequncer im working on,
its not advancing steps alongside my pcb circuit, anyone identify anything weird?
// Timing configurables, all values are in microseconds.
// You might need to tweak these depending on your hardware.
#define CLOCK_LENGTH 250
#define GATE_DELAY 1000
// Defines the max length in microsecs of the gate length pot.
#define MAX_GATE_TIME 1000000
// sensor inputs
#define PIN_SPEED A0
#define PIN_GATELEN A1
#define PIN_4051_Z A2
#define PIN_MAINSW A3
#define PIN_CLKINSW A4
#define PIN_GATESW A5
#define PIN_CLKIN 2
#define PIN_RSTIN 3
// sensor outputs
#define PIN_CLKOUT 7	 // PD7
#define PIN_GATEOUT 12   // PB4
#define PIN_594_SER 10   // PB2
#define PIN_594_RCLK 11  // PB3
#define PIN_594_SRCLK 13 // PB5
// 4051 port configuration.
// You can't change this without changing PORTD logic below.
#define PIN_4051_S0 4
#define PIN_4051_S1 5
#define PIN_4051_S2 6
	pinMode(PIN_CLKOUT, OUTPUT);
	pinMode(PIN_GATEOUT, OUTPUT);
	pinMode(PIN_4051_S0, OUTPUT);
	pinMode(PIN_4051_S1, OUTPUT);
	pinMode(PIN_4051_S2, OUTPUT);
	pinMode(PIN_594_SER, OUTPUT);
	pinMode(PIN_594_RCLK, OUTPUT);
	pinMode(PIN_594_SRCLK, OUTPUT);
	pinMode(PIN_CLKIN, INPUT_PULLUP);
	attachInterrupt(digitalPinToInterrupt(PIN_CLKIN), clock_receive, RISING);
	attachInterrupt(digitalPinToInterrupt(PIN_RSTIN), reset_receive, RISING);
	randomSeed(analogRead(0));
	shiftOut2(0x01); // Turn on first led
int step = 0;
int stepCount = 0;
int maxSteps = 0;
int reverse = 0;
int substep = 0;
unsigned long lastNotePlayed = micros();
bool gateOpen = false;
// clock_receive is a hardware interrupt callback.
byte clkState = LOW;
volatile byte clock = LOW;
void clock_receive()
	clock = !clock;
// reset_receive is a hardware interrupt callback.
volatile byte reset = LOW;
void reset_receive()
	reset = !reset;
// myAnalogRead reads the analog input twice
// to stabilize the ADC input before returning
// a value.
int myAnalogRead(int pin)
	analogRead(pin);
	return analogRead(pin);
void doreset()
	reset = false;
	stepCount = maxSteps;
	step = -1;
	reverse = 0;
	substep = -1;
	clkState = LOW;
	clock = HIGH;
	if (reset)
		doreset();
	// gatelen goes from 0.0 to 1.0
	float gatelen = float(myAnalogRead(PIN_GATELEN)) / 1024.0;
	// calc note length in microseconds, this ranges from about 6 to 300 bpm or so
	unsigned long speed = 45000000.0 / (float(myAnalogRead(PIN_SPEED)) + 10.0);
	// clocksw is high if an external clock is plugged in.
	int ic = myAnalogRead(PIN_CLKINSW);
	bool intclock = ic < 512;
	// if the gate is still open, turn it off after some time.
	if (gateOpen && lastNotePlayed < micros() - (MAX_GATE_TIME * gatelen))
		digitalWrite(PIN_GATEOUT, LOW);
		shiftOut2(0);
		gateOpen = false;
	// decide if we want to trigger the next step of the sequencer.
	if (intclock)
		// wait for certain time in internal clock mode
		if (lastNotePlayed > micros() - speed)
			return;
		// wait for clock signal if ext clock is connected
		if (clkState == clock)
			return;
		clkState = clock;
	// always close the gate before sending a new note.
	if (gateOpen)
		shiftOut2(0);
		gateOpen = false;
	gateOpen = do_step();
// do_step outputs clock + gate and if
// necessary advances the sequencer by a step.
bool do_step()
	bool advanced = false;
	stepCount++;
	if (stepCount >= maxSteps)
		stepCount = 0;
		advance();
		advanced = true;
	// Set PIN_4051_Sxx
	PORTD = (PORTD & 0b10001111) | (step << 4);
	// Check the value of the step switch.
	// It's either 0, 511 or 1023 (with some margin).
	int gatesw = myAnalogRead(PIN_GATESW);
	int sw = 0; // default off (middle position)
	if (gatesw > 400 && gatesw < 600)
		sw = 1; // down
	if (gatesw > 900)
		sw = 2; // up
	// Wait for this many microseconds after switching the 4051
	// before sending the gate signal.
	delayMicroseconds(GATE_DELAY);
	// toggle clock and gate if the gate switch is on.
	digitalWrite(PIN_CLKOUT, HIGH);
	bool gate = sw == 1 || (sw == 2 && advanced);
	if (gate)
		digitalWrite(PIN_GATEOUT, HIGH);
		shiftOut2(1 << step);
	// clock time is 10us
	delayMicroseconds(CLOCK_LENGTH);
	digitalWrite(PIN_CLKOUT, LOW);
	maxSteps = map(myAnalogRead(PIN_4051_Z), 0, 1023, 8, 1); // / 128;
	// return whether or not the gate was triggered.
	return gate;
// advance the sequencer in forward mode
void advance_fwd(int max)
	step++;
	if (step >= max)
		step = 0;
// advance the sequencer in pingpong mode
void advance_pingpong()
	if (reverse)
		step--;
		if (step < 0)
			step = 7;
			reverse = 0;
			step = 1;
		step++;
		if (step >= 8)
			step = 0;
			reverse = 1;
			step = 6;
// advance the sequencer in substep mode
void advance_substep(int len)
	substep++;
	if (substep >= len)
		substep = 0;
	if (substep < len - 4)
		// play notes 1-4
		step = substep % 4;
		// play notes 5-8
		step = substep + 8 - len;
void advance_random()
	step = random(8);
byte loop2[] = {0, 1, 2, 3, 4, 0, 1, 2, 3, 5, 0, 1, 2, 3, 6, 0, 1, 2, 3, 7};
void advance_loop2()
	substep++;
	if (substep >= 20)
		substep = 0;
	step = loop2[substep];
byte rndsteps[8];
int rndstep;
void advance_random_preset_init()
	step = random(8);
	rndstep = 0;
	for (int i = 0; i < 8; i++)
		rndsteps[i] = i;
		int x = random(7) + 1;
		byte t = rndsteps[x];
		rndsteps[x] = rndsteps[i];
		rndsteps[i] = t;
void advance_random_preset()
	rndstep++;
	if (rndstep >= 8)
		rndstep = 0;
	step = rndsteps[rndstep];
int lastmainsw = 0;
// advance advances the sequencer by one step
void advance()
	int mainsw = map(myAnalogRead(PIN_MAINSW), 0, 1023 - (1023 / 12), 11, 0);
	bool changed = false;
	if (lastmainsw != mainsw)
		lastmainsw = mainsw;
		//    step = 0;
		//    substep = 0;
		changed = true;
	switch (mainsw)
	case 0:
		advance_fwd(4);
	case 1:
		advance_fwd(6);
	case 2:
		advance_fwd(8);
	case 3:
		advance_pingpong();
	case 4:
		advance_substep(16);
	case 5:
		advance_substep(24);
	case 6:
		advance_substep(32);
	case 7:
		advance_loop2();
	case 8:
		advance_random();
	default:
		if (changed)
			advance_random_preset_init();
		advance_random_preset();
// shiftOut writes a byte to the hc594 shift register
// used to control the LEDs.
void shiftOut2(byte data)
	digitalWrite(PIN_594_RCLK, LOW);
	shiftOut(PIN_594_SER, PIN_594_SRCLK, MSBFIRST, data);
	digitalWrite(PIN_594_RCLK, HIGH);
Please clarify your request. Do you have problems with the code? Is it compiles? If not, show the compiler output
In case the code compiles, is it works as expected? If no - give us more info about how the code works, how it expect to work and what the difference between this two cases.
What is the board you use?
hey - sorry yeah, so im using an arduino nano v3, it does compile, specifically in theory im mainly concerned about the advancing of steps in this piece of code.
the code generates a few different ways to generate 0-5v voltage but it stalls on start up and does not advance nor trigger to the next step.
im also aware it could be a hardware problem but just wanted to see if anything looked weird to anyone else off the bat
Have you put some serial to check if the code fails in a specific place? That would be debug 101, print “I am here” and print variable should be and variable is! At what point did the “problem” manifest. Normally you code and breadboard in chunks so that you know everything worked up to a certain point and bug is somewhere between last working code/hardware and current
yeah this is where its getting weird, it should work, ill have to rewind
I think you're using micros wrong here:
Look - if the speed variable contains a time interval, as I see in that line:
then the condition above will not work correctly.
Note, the micros continuously increases from the start of the program. To measure intervals, you need to memorize the micros value at the start and then look at the difference between the current micros and the memorized value.
See tutorials on using millis - micros works similarly
And yet, using a return to rewind the loop() is not a good idea.
Sorry, my reasoning about the micros in previous post was wrong, I did not fully understand the code.
Ignore them
no prob, i appreciate the look over, using return to rewind loop not so clean?
