I don't ever see an "uploading" message. The IDE immediately reports and error as soon as it's done compiling
Here's the code, down to where the loop starts. I don't see anything in the setup code that would be tickling the RX or TX pins:
// Load Libraries
#include <Wire.h>
#include <LCD.h>
// Load Libraries for DS1820 and OneWire
#include <OneWire.h>
#include <DallasTemperature.h>
// Define variables LDCD:
#define I2C_ADDR 0x27 // Define I2C Address where the PCF8574A is
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
// Data wire is plugged into pin 12 on the Arduino
#define T_bus_0 0 // Usually pin 4
#define T_bus_1 1
// Setup oneWire instance to communicate with devices
OneWire oneWire0(T_bus_0);
OneWire oneWire1(T_bus_1);
// Pass oneWire reference to Dallas Temperature.
DallasTemperature sensor0(&oneWire0);
DallasTemperature sensor1(&oneWire1);
int n = 1;
//Initialise the LCD
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
float intempf = 74.3 ;
float outtempf = 65.7 ;
float tanktempf = 68.4 ;
float refertempf = 25.1;
float battf = 12.7;
float ampsf = -3.2 ;
int intemp = 74 ;
int outtemp = 68 ;
int tanktemp = 47 ;
int refertemp = 28 ;
int batt ;
int amps ;
int inmax = 30;
int inmin = 90;
int outmax = 30;
int outmin = 90;
int tankmin =32;
int tankmax = 70;
int refermax = 10;
int refermin = 32;
// associate output pins with LEDs
int freshlow = 11 ;
int freshmid = 2 ;
int freshfull = 3 ;
int blacklowest = 4 ;
int blacklow = 5 ;
int blackmid = 6 ;
int blackfull = 7 ;
int graylow = 8 ;
int graymid = 9 ;
int grayfull = 10 ;
int pause = 500 ;
char degree = B11011111 ;
// Up arrow
byte uparrow[8] = {
B00100,
B01010,
B10101,
B00100,
B00100,
B00100,
B00100,
B00100 } ;
// Down arrow
byte downarrow[8] = {
B00100,
B00100,
B00100,
B00100,
B00100,
B10101,
B01010,
B00100 } ;
// ----------------------Setup------------------------
// Define LCD as 20 column x 4 rows
lcd.begin (20,4);
// Switch on the backlight
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
// assignes each segment a write number
lcd.createChar(1,uparrow);
lcd.createChar(2,downarrow);
lcd.setCursor ( 0, 0 );
lcd.print("Ver: Monitor 1.0.1") ;
delay(2000) ;
lcd.print(" ") ;
// set ouput pins
pinMode(2, OUTPUT) ;
pinMode(3, OUTPUT) ;
pinMode(4, OUTPUT) ;
pinMode(5, OUTPUT) ;
pinMode(6, OUTPUT) ;
pinMode(7, OUTPUT) ;
pinMode(8, OUTPUT) ;
pinMode(9, OUTPUT) ;
pinMode(10, OUTPUT) ;
pinMode(11, OUTPUT) ;
digitalWrite(2, HIGH) ;
digitalWrite(3, HIGH) ;
digitalWrite(4, HIGH) ;
digitalWrite(5, HIGH) ;
digitalWrite(6, HIGH) ;
digitalWrite(7, HIGH) ;
digitalWrite(8, HIGH) ;
digitalWrite(9, HIGH) ;
digitalWrite(10, HIGH) ;
digitalWrite(11, HIGH) ;
// Test output pins and LEDs
digitalWrite(11, LOW) ;
delay(pause) ;
digitalWrite(2, LOW) ;
delay(pause) ;
digitalWrite(3, LOW) ;
delay(pause) ;
digitalWrite(4, LOW) ;
delay(pause) ;
digitalWrite(5, LOW) ;
delay(pause) ;
digitalWrite(6, LOW) ;
delay(pause) ;
digitalWrite(7, LOW) ;
delay(pause) ;
digitalWrite(8, LOW) ;
delay(pause) ;
digitalWrite(9, LOW) ;
delay(pause) ;
digitalWrite(10, LOW) ;
delay(pause) ;
// digitalWrite(freshlow, LOW) ;
// digitalWrite(freshmid, LOW) ;
digitalWrite(blacklowest, LOW) ;
// ----------------- Start the Loop ---------------------
