Here, https://wiki.keyestudio.com/images/d/d9/Install图片14.png it is shown as if the screws perfectly allign with the nano sheild, however that is not the case whatsoever. The best angle would only allign with 2 out of 4 M3x10mm dual-pass copper pillar, and any other placement wouldn’t allign at all, or if it does, it will just allign with one.
Hi @newbiewilliam. It looks like you have the circular piece of green acrylic upside down. Disassemble the kit, flip that piece over, and then try mounting the shield to it.
I don't know it, but it certainly looks like it from this picture you shared:
Unlike the other end of the shield, the holes on this end of the shield are offset rather than equally distant from their corresponding sides of the shield. The holes on the acrylic piece are also offset, but you can see the offsets on the acrylic are in opposite directions than the ones on the shield. By flipping the acrylic over, the offsets of its holes will be aligned with the offsets on the shield.
