This is my first time using the Forum.
I have been trying for 2 days to get both works simultaneously but with independent compare match value (Timer2 OCR2A & B) and control its own output accordingly . Each OCR2A and OCR2B has different match compare value. Also each output pin (11 ,3) (OCR2A & B) would be active ( PWM) output for a duration and then OFF for a different duration. I just could not make this works.
Please help me.
The following is my sketch.
#include <Wire.h>
const int ocr2top = 255; //Mode 1 default top xFF.
float i = 0;
float j = 0;
// OC2A arduino pin11 (PB3) OC2B arduino pin3 (PD3)
// mode1 1 phasecorrection
TCCR2A = (1 << COM2A1)+(1 << COM2B1) + (0 << WGM21) + (1 << WGM20);
// WGM20 set -> Mode 1, phasecorrect xFF top
// COM2A1=1 and COM2B0 = 0 means clear OC2A n B compare match.
TCCR2B = (1 << CS22) + (1 << CS21) + (0 << CS20) + (0 << WGM22); // prescaler
//pinMode(3, OUTPUT); //OCR2B
//pinMode(11, OUTPUT); //OCR2A
delay ( 100);
//==================== LOOP ===========================
// -------------------OCR2A--------------
if (i < 400)
i = i + 1;
else {
i = 0;
if (( i > 0 ) && (i < 4))
fun_OCR2A(140);
if ((i > 210) && (i < 214))
fun_FWDoff();
//--------------OCR2B------------
if (j < 600)
j = j + 1;
else {
j = 0;
if (( j > 0 ) && (j < 9 ))
fun_OCR2B(204);
else if ((j > 300) && (j < 308))
fun_REVoff();
//========= functions ==========================
void fun_FWDoff()
OCR2A = 0 ;
digitalWrite (11, LOW);
Serial.print(" OCR2A off= ");
Serial.println(OCR2A);
void fun_OCR2A(int val)
OCR2A = val;
Serial.print(" OCR2A = ");
void fun_REVoff()
OCR2B = 0 ;
digitalWrite (3, LOW);
Serial.print(" OCR2B off= ");
Serial.println(OCR2B);
void fun_OCR2B(int val)
pinMode(3, OUTPUT);
OCR2B = val;
Serial.print(" OCR2B = ");
