There is a formula in the datasheet, try 209 for your OCR1A value.
Also, I'd suggest you don't leave the timer on all the time and just enabling the outputs. Set your TCCR1A value at initialization and in your on function, set the CS10 bit and in the off function clear it.
Thank you all kindly. I read more and cobbled together something different but working. My understand of the timing registers is a little better - my love of data sheets is just as low as ever.
Nick Gammons 'Modulating a 38 kHz carrier with a 500 Hz signal', on his blog Gammon Forum : Electronics : Microprocessors : Timers and counters is what I used, modified to remove the input variable. It's not the first time Nick Gammon has save the day for me, so an extra thanks to him.
const byte LED = 10; // Timer 1 "B" output: OC1B
pinMode (PB5, OUTPUT);
pinMode (LED, OUTPUT);
PORTB |= (1 << PB5);
delay(300);
PORTB &= ~(1 << PB5);
delay(300);
// set up Timer 1 - gives us 38.500 kHz
// Fast PWM top at OCR1A
TCCR1A = bit (WGM10) | bit (WGM11) | bit (COM1B1); // fast PWM, clear OC1B on compare
TCCR1B = bit (WGM12) | bit (WGM13) | bit (CS10); // fast PWM, no prescaler
OCR1A = 419; // zero relative
OCR1B = 209; // 50% duty cycle
} // end of setup
delay(5000);
TCCR1A &= ~(1<<COM1B1);
delay(3000);
TCCR1A |= (1<< COM1B1);
I've done as 6v6gt suggests and will use the TCCR1A register as the switch and put that in my on()/off() functions.
Interestingly, the numbers that the original code generated for the OCR1A count didn't produce a 38000Hz signal for me. It was close but needed modified. I'm putting this down to slight variances in IR receiver circuit that's running on a an Attiny85.
