Nano + TMC2130 - SPI/StallGuard not working (SOLVED)
hi,
i'm experienced using TMC2100 drivers, and i've recently bought a TMC2130 to try running it through SPI and thus have the amazing load sensing capacity of these drivers (StallGuard).
however, i have tried myriads of different setups and configurations and i cannot seem to be able to run these drivers in SPI mode. i've checked pinout, code, checked power supply, correct current limiting, checked board pins with a multimeter and etc and everything seems to be running fine.
am I missing something? or did i get very unlucky to have bought a brand new motor driver that came with its SPI interface faulty? the motor does not even block while on SPI mode! in standalone mode (non-spi, soldered pads bellow) it works just fine though.
details:
/picture: (attached)
/code:
 * Author Teemu Mäntykallio
 * Plot TMC2130 or TMC2660 motor load using the stallGuard value.
 * You can finetune the reading by changing the STALL_VALUE.
 * This will let you control at which load the value will read 0
 * and the stall flag will be triggered. This will also set pin DIAG1 high.
 * A higher STALL_VALUE will make the reading less sensitive and
 * a lower STALL_VALUE will make it more sensitive.
 * You can control the rotation speed with
 * 0 Stop
 * 1 Resume
 * + Speed up
 * - Slow down
#include <TMCStepper.h>
#define MAX_SPEED        40 // In timer value
#define MIN_SPEED      1000
#define STALL_VALUE      15 // [-64..63]
#define DIR_PIN    5
#define STEP_PIN   6
#define EN_PIN    7
#define CS_PIN    10
#define SCK_PIN   17
#define SW_MOSI  11
#define SW_MISO  12
#define SW_SCK   13
#define R_SENSE 0.11f // Match to your driver
                      // SilentStepStick series use 0.11
                      // UltiMachine Einsy and Archim2 boards use 0.2
                      // Panucatt BSD2660 uses 0.1
                      // Watterott TMC5160 uses 0.075
// Select your stepper driver type
//TMC2130Stepper driver(CS_PIN, R_SENSE);                           // Hardware SPI
TMC2130Stepper driver(CS_PIN, R_SENSE, SW_MOSI, SW_MISO, SW_SCK);   // Software SPI
using namespace TMC2130_n;
#define STEP_PORT     PORTF // Match with STEP_PIN
#define STEP_BIT_POS      0 // Match with STEP_PIN
ISR(TIMER1_COMPA_vect){
  //STEP_PORT ^= 1 << STEP_BIT_POS;
  digitalWrite(STEP_PIN, !digitalRead(STEP_PIN));
  SPI.begin();
  Serial.begin(250000);
  while(!Serial);
  Serial.println("\nStart...");
  pinMode(EN_PIN, OUTPUT);
  pinMode(STEP_PIN, OUTPUT);
  pinMode(CS_PIN, OUTPUT);
  pinMode(DIR_PIN, OUTPUT);
  pinMode(MISO, INPUT_PULLUP);
  digitalWrite(EN_PIN, LOW);
  driver.begin();
  driver.toff(4);
  driver.blank_time(24);
  driver.rms_current(400); // mA
  driver.microsteps(16);
  driver.TCOOLTHRS(0xFFFFF); // 20bit max
  driver.THIGH(0);
  driver.semin(5);
  driver.semax(2);
  driver.sedn(0b01);
  driver.sgt(STALL_VALUE);
  // Set stepper interrupt
    cli();//stop interrupts
    TCCR1A = 0;// set entire TCCR1A register to 0
    TCCR1B = 0;// same for TCCR1B
    TCNT1  = 0;//initialize counter value to 0
    OCR1A = 256;// = (16*10^6) / (1*1024) - 1 (must be <65536)
    // turn on CTC mode
    TCCR1B |= (1 << WGM12);
    // Set CS11 bits for 8 prescaler
    TCCR1B |= (1 << CS11);// | (1 << CS10);
    // enable timer compare interrupt
    TIMSK1 |= (1 << OCIE1A);
    sei();//allow interrupts
  static uint32_t last_time=0;
  uint32_t ms = millis();
  while(Serial.available() > 0) {
    int8_t read_byte = Serial.read();
    #ifdef USING_TMC2660
      if (read_byte == '0')      { TIMSK1 &= ~(1 << OCIE1A); driver.toff(0); }
      else if (read_byte == '1') { TIMSK1 |=  (1 << OCIE1A); driver.toff(driver.savedToff()); }
    #else
      if (read_byte == '0')      { TIMSK1 &= ~(1 << OCIE1A); digitalWrite( EN_PIN, HIGH ); }
      else if (read_byte == '1') { TIMSK1 |=  (1 << OCIE1A); digitalWrite( EN_PIN,  LOW ); }
    #endif
    else if (read_byte == '+') { if (OCR1A > MAX_SPEED) OCR1A -= 20; }
    else if (read_byte == '-') { if (OCR1A < MIN_SPEED) OCR1A += 20; }
  if((ms-last_time) > 100) { //run every 0.1s
    last_time = ms;
    DRV_STATUS_t drv_status{0};
    drv_status.sr = driver.DRV_STATUS();
    Serial.print("0 ");
    Serial.print(drv_status.sg_result, DEC);
    Serial.print(" ");
    Serial.println(driver.cs2rms(drv_status.cs_actual), DEC);
/parts:
thanks!
It took me a while to realize the mistake ; ). SDO/SDI pins were inverted, and a couple of other small things in the code too.
StalllGuard works like a charm, and is a lot more sensitive than I expected ; ).
 * 0 Stop
 * 1 Resume
 * + Speed up
 * - Slow down
#define STALL_VALUE      0 // [-64..63]
#define EN_PIN           7  // Enable
#define DIR_PIN          5  // Direction
#define STEP_PIN         6  // Step
#define CS_PIN           10 // Chip select
#define SW_MOSI          11 // Software Master Out Slave In (MOSI)
#define SW_MISO          12 // Software Master In Slave Out (MISO)
#define SW_SCK           13 // Software Slave Clock (SCK)
//TMC2130Stepper driver(CS_PIN, R_SENSE, SW_MOSI, SW_MISO, SW_SCK); // Software SPI
// Using direct register manipulation can reach faster stepping times
  SPI.begin();
  while(!Serial);
  driver.begin();
  driver.toff(4);
  driver.rms_current(700); // mA
  driver.en_pwm_mode(true);
  driver.pwm_autoscale(true);
  driver.THIGH(0);
  driver.semin(5);
  driver.semax(2);
  driver.sedn(0b01);
    // turn on CTC mode
    #else
    #endif
    last_time = ms;
    Serial.print("0 ");
    Serial.print(" ");
Moderators may close the thread.
Cheers.
