Hello Humanity!
got Nano V3.0 Board ATmega328P. not recognized on device manager and not showing board info.
Have difficulty uploading sketches with no error.
Is there anything which can be done to make it work properly ? Thanks
Is there nothing anywhere in device manager, not even under Universal Serial Bus Controllers? If so, check the cable; I think it's unlikely if you have a miniUSB cable, but you might have a charge-only cable so try different cables.
If it's a clone with a CH340 TTL-to-USB converter, did you install the driver; you can download it from CH341SER.ZIP - NanjingQinhengMicroelectronics.
