Nano v3.0 Unable to install drivers?
I tried to install the CH340 drivers but nothing works. I get a message saying "The drive is successfully Pre-installed in advance!". So did it install?
I go to device manager and don't see the nano. Arduino software doesn't see it either. Yes, the nano is plugged in.
The nano I have is this one:
https://www.aliexpress.com/i/32980796969.html
I click on the drive file CH341SER.exe and it does the whole extracting thing, but if I hit uninstall it always says no drivers found. Hitting install will be how I described above.
I can confirm my Uno does work though.
How do i get it to install?
Make sure the USB cable is completely plugged into both the Arduino board and the PC.
You may have a damaged/defective or charge-only USB cable. Try a different cable.
traderjoe:
That should be sufficient; it worked for me like that on several systems. Chinese English is not always the best.
